Old 12-29-2011, 11:15 PM   #1
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Question Clean/strip my frame??
I have my frame stripped of all extraneous pieces and I am ready to clean and prep it for paint. The truck is going to be a driver, so I am going to spray bomb it in my garage with primer and satin black. It has a little surface rust but nothing too bad. I have heard of people using oven cleaner, but have never tried it. I have used a wire wheel on another frame I have, but that... well... it sucks. So, what have you all done, short of taking it to a blaster, that worked well?
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 12-29-2011, 11:27 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Clean/strip my frame??
The oven cleaner from the dollar store and a power washer
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 12-29-2011, 11:47 PM   #3
a2tripp
a2tripp's Avatar
wire wheel is a good start, it will break up all that loose stuff, I'd use POR marine clean, works good, no residue, and biodegradable
89 GMC V3500
Alaska members check in
a2tripp is offline   Reply With Quote
Old 12-30-2011, 12:49 AM   #4
ItsRandy
ItsRandy's Avatar
I used oven cleaner on mine and it worked pretty good. The dollar store stuff is cheap (a dollar), contains Sodium Hydroxide (LYE) and works well on grease. The Easy-Off brand is pretty wicked, will remove paint, contains Methylene Cloride (the same stuff that's in paint stripper) and costs about $7 a can. The problem I found was getting the goo out of the hard to reach areas (around rivet heads and such), even with a pressure washer. You have to be careful where you wash the stuff off at, it kills plants (my lawn) and other living things and your local government officials my not like it if you wash it down the gutter.
ItsRandy is offline   Reply With Quote
Old 12-30-2011, 01:23 AM   #5
sharpmark
i used a combination of oven cleaner,degreaser and a water blaster but i also had to scrap alot with a paint scraper where it was stuck on real thick- unfortunately theres no easy way around it if you want to save on sandblasting/or dipping costs.like has been said already-around the rivits and inside the chassis rails where the crossmembers go is the hardest.
cheers
1969 stepside-305/4spd/12 bolt posi
http://67-72chevytrucks.com/vboard/s...d.php?t=477157
1968 pontiac lemans convertible-350/pwrglde/10 bolt
1934 oldsmobile sedan-350/350/12 bolt posi
1930 model a pickup-350/350/jag ind
1928 model a roadster-283/350/9"
sharpmark is offline   Reply With Quote
