Old 12-30-2011, 10:53 AM   #1
El Campo
El Campo's Avatar
Why do 72 frames look tweaked in the back?
My frame looks like the back is a little twisted and I have noticed the same thing on a lot of other frames also. Is this my imagination or is it due to the tracking arm being on an angle? I'm paranoid now that when I boxed the frame that I welded it tweaked. Anyone know how to measure it and be sure?
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 12-30-2011, 05:44 PM   #2
litew8
litew8's Avatar
Re: Why do 72 frames look tweaked in the back?
It's the member that sits at an angle and is normal.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 12-30-2011, 06:06 PM   #3
El Campo
El Campo's Avatar
So are u saying that if I set the bare frame on my shop floor (which is a known flat surface) and measure it from the ground that the frame rails will be exactly the same distance from floor or should be?
Hook em Horns!!!
Old 12-30-2011, 06:17 PM   #4
litew8
litew8's Avatar
Maybe I'm misunderstanding your question. This is what I'm refering to as being angled. The middle brace.
Old 12-30-2011, 06:29 PM   #5
Marshall Truck Fab
measure across from a identical point on each rail to the end of other rail. Like an X. This measurement should be identical.
Marshall Truck Fab is offline   Reply With Quote
Old 12-30-2011, 06:36 PM   #6
cdowns
cdowns's Avatar
in the factory service manual there is the info on the measurements of the frame and how to measure it
Old 12-30-2011, 07:27 PM   #7
El Campo
El Campo's Avatar
Yes you are exactly right that's what I am referring to. Hmm too bad I don't have one of those.. The reason I'm worried is because I cut the rear frame horns off of Attempt/Mistake #2 and want to check it all before I paint it and find out its all screwed up
Hook em Horns!!!
