12-30-2011, 11:22 AM | #1 |
Fuel Pump
Where is the best location to install a after market fuel pump? I just installed my second one within four months. What I'm I doing wrong?
12-30-2011, 11:34 AM | #2 |
Re: Fuel Pump
Close to the tank, about mid-level so the pump doesn't have to lift fuel a long ways. Is it injected or carburated? Good luck, Ron
12-30-2011, 11:41 AM | #3 |
Re: Fuel Pump
aftermarket mechanical? or electric?
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] 1999 k3500 crew cab dually 6.5tdi/4l80e |
12-30-2011, 11:46 AM | #4 |
Re: Fuel Pump
79K30dually - a little side note - I have a 1974 c-10 with a 1988 350 that as a carb. On the 1988 350's I believe the fule pump was in the tank, but with my tank being the 1974 model I have to go with a after market pump. As it stands right now I have the pump under the hood on the frame.
12-30-2011, 11:46 AM | #5 |
Re: Fuel Pump
Goldfinger - eletric fuel pump
12-30-2011, 12:04 PM | #6 |
Re: Fuel Pump
what about a rear tank like an 86 and use the corresponding fuel pump
12-30-2011, 12:04 PM | #7 |
Re: Fuel Pump
Different pumps want different locations Some pumps are puller pumps some are pusher pumps...When I bought my 77 Blazer it had a Mr Gasket pump under the hood on the frame rail, it was supposed to be a pusherpump but they installed in upfront. There was too much heat there and it would vaporlock and quit running. I could either install it in the rear close to the tank or go back to mechanical. I went mech
12-30-2011, 12:06 PM | #8 |
Re: Fuel Pump
What is it that you want the instant start of an electric pump?
12-30-2011, 12:08 PM | #9 |
Re: Fuel Pump
also may i suggest an external fuel pump that is timed to get you a shot oof fuel then shut off and let a mech pump handle running
12-30-2011, 12:21 PM | #10 |
Re: Fuel Pump
The pump that was on there before a eletic pump under the driver side of the cab, but when it went out I moved that pump (that is the one that just went out) right next to the tank. Well I thought now I would relocate it under the hood.
The only pump that will work on this truck is a eletrical one b/c on the 1988 350 it doesnt have a slot for the rod (in the block) to push the mech pump or I would put a mech pump on it and be done with it. |
12-30-2011, 04:35 PM | #11 |
Re: Fuel Pump
In my opinion, You had it in the correct place. What was the pressure rating of the pump? Did you have a return line? How was it wired, through the oil pressure switch? How close to the exhaust?
12-30-2011, 04:38 PM | #12 |
Re: Fuel Pump
No I didn't have a return line, it was wired to a 20amp fuse and then to the streeing colum.
12-30-2011, 06:54 PM | #13 |
The One And Only !!!
Re: Fuel Pump
I went through 3 frame mounted pumps that were installed correctly in 6 months time, Their just not worth crap on a DD.....
Install a later model TBI tank with the pump inside, They run 9 to 12 psi, Add a return style pressure regulator with gauge near the carb adjusted to 6-7 psi then run a return line back to the tank. Wire the pump through a 30 amp relay to switched power. I haven't had a pump issue in 3 years since doing the above.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
01-06-2012, 11:43 PM | #14 |
Big Gulps Huh? Whelp...
Re: Fuel Pump
If you are going through pumps that fast, quit buying cheap junk...spend money for a good pump, wire it correctly through a 30 amp relay and you will never look back!
"The Ghost II" - 1987 V30 CC, 14-BFF (2nd Design Heavy Ribbed HD) SRW Conversion, 454/4L80E/205, 6" Springs, 35" Toyo MT's on 17" Classic II's, Full Audio System, Lot of Other Goodies!
01-07-2012, 08:02 AM | #15 |
Re: Fuel Pump
Holley "Red" pumps aren't cheap !
01-07-2012, 12:28 PM | #16 |
Re: Fuel Pump
Then wire it properly so it isn't straining the pump...I have wired many of the Holley Blue pumps as a priming pump to fill surge tanks and only had one ever get noisy and stop working, so I doubt the pump itself is the issue, you should try wiring it via a relay though.
01-07-2012, 01:10 PM | #17 | |
Re: Fuel Pump
Didn't change a thing with the relay/wiring, Only installed the tank with OEM pump. That was 3 years ago as mentioned.....
01-07-2012, 01:24 PM | #18 |
Re: Fuel Pump
Okay, I was talking to the original poster, not you...His set-up was simply wired through a fuse to the steering column somewhere...
