Old 12-30-2011, 07:22 PM   #1
davepl
davepl's Avatar
Are big block trucks 2-bolt or 4-bolt mains?
My 1970 has the L-47 402, which I assume is pretty close to the Impala/Camaro 396/325.
I'm wondering if trucks got 4-bolt mains... I couldn't find any specs on the L-47 (if someone knows, please point me at them!).
Or is it a case of "some were, some weren't"?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-30-2011, 11:30 PM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Are big block trucks 2-bolt or 4-bolt mains?
According to my books they could have been 2 or 4 bolts in the trucks
It really is not that important in the big skeem on things
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 12-31-2011, 08:32 AM   #3
Get your casting numbers off the front of the block and look it up on www.nastyz28.com . BTW,all '70s were 402s,even SS396s.
Old 12-31-2011, 03:32 PM   #4
davepl
davepl's Avatar
I did look it up on nastyz28, but it just said "L-47 402 310hp". Is there some other resource on that site that breaks it down by 2-bolt vs 4-bolt? I couldn't find one.
Old 12-31-2011, 03:39 PM   #5
too much stuff
Roadtrip!
too much stuff's Avatar
If you really need to know, drop the oil pan.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 12-31-2011, 03:51 PM   #6
1972RedNeck
1972RedNeck's Avatar
You might be able to see through the oil plug hole with a flashlight.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 12-31-2011, 07:22 PM   #7
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Why is it really all that important?
ProStreet68SB is offline   Reply With Quote
Old 12-31-2011, 10:42 PM   #8
71 super
71 super's Avatar
It is more than likely a two bolt. the one in my 71 is a 2 bolt. Heck it does not matter these things in stock form dont turn enough rpm to worry nor do they need to. Drive it and enjoy the bb
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 12-31-2011, 10:45 PM   #9
Livrat
Member #1049
Livrat's Avatar
I do believe there were no 4 bolt 396's or 402's in our trucks, from the factory the only 4 bolts were the 375hp/396, 425hp/396's and higher hp 427's.
I have been lead to believe from personal experience, (I have owned and built many a big block in the last 30 years):
One way to tell is look above the oil filter boss.. all the early 4 bolt blocks were drilled and tapped for an external oil cooler, if the block has two pipe plugs (one 1/2" and one 1/4') its a 4 bolt. the 2 bolts only had a single 1/4' threaded boss, (its where your oil pressure gauge line is attached).
Livrat is offline   Reply With Quote
Old 01-01-2012, 02:42 AM   #10
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
I have played the 2 bolt/4 bolt lottery so many times and have never came up with a 4 bolt. A 2 bolt with a steel crank is good for about 600 HP. One place to find 4 bolts is in motorhomes!
prostreetC-10 is offline   Reply With Quote
Old 01-01-2012, 03:00 AM   #11
ProStreet68SB
I'll be at 800hp on a stock 2bolt block.
But lets not forget that 4-bolts are weaker.
Old 01-01-2012, 11:40 AM   #12
1972RedNeck
What? How?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 01-01-2012, 11:54 AM   #13
mightymouse
mightymouse's Avatar
if its like a small block i always heard a 2-bolt is stronger. cause the main webbing is thicker than a 4-bolt . Ive heard the best thing to do is have 2-bolt block machined for 4-bolt main caps. looking at it makes sense.but i'm no motor man just things Ive been told...
mightymouse is offline   Reply With Quote
Old 01-01-2012, 10:58 PM   #14
ProStreet68SB
Originally Posted by 1972RedNeck View Post
What? How?
This. Except you have 2 bolt bolt block machined for splayed 4 bolt mains.
Old 01-01-2012, 11:27 PM   #15
gearys 5600
gearys 5600's Avatar
This x2^^^ The only 4-bolts that I personally have seen are L-78 375hp 396,Ls-6 and Ls7 454's, and the high horse 427's
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 01-01-2012, 11:40 PM   #16
indianbullet
Location: North Cal and no Sac or Bay area is not NORTH
If you find a big block look at the pipe plug above the oil filter. If it has a huge plug 1" pipe rather than the 3/4" pipe plug it will be a 4-bolt. At least this has held true on all the blocks built before the early 80's when I was in the machine shop.
As for small blocks back in the day. I've seen many a case of beer lost by those that thought they could pin point one via casting #'s etc. gotta pull the pan.
Never argue with an idiot, they will bring you to their level and beat you with experience..
indianbullet is offline   Reply With Quote
Old 01-01-2012, 11:52 PM   #17
Livrat
Member #1049
Livrat's Avatar
I stand corrected... it is a 1" pipe plug above the oil filter and not a 1/2" like I posted above, Indianbullet thanks for the clarification!
Old 01-02-2012, 12:13 AM   #18
mcbassin
Still Learning
mcbassin's Avatar
I pulled my pan to change the gasket back in the 80s only to be disappointed to see it was a 2 bolt. At the time I remember thinking someone put a car motor in my truck. I thought all truck big blocks were 4 bolts then. That was before I knew it really didn't make any difference.
mcbassin is offline   Reply With Quote
Old 01-02-2012, 07:46 AM   #19
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Got a question then... My 69 wrecker has it's original 350 and it has 4 bolt mains. (I think I heard all the 350's in these trucks were 4 bolt but not sure)
Why would they use a 4 bolt in a small block and not the big block?
I can see why it's not important for a stock built engine so why did any of them have it? (just wondering & for conversation purposes)...
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 01-02-2012, 08:15 AM   #20
GRX
GRX's Avatar
x2.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 01-03-2012, 10:37 PM   #21
indianbullet
Every stock 350 I have pulled out of these truck has been of the nodular Iron
4-bolt main cap variety. Very desirable blocks as the years progressed the blocks went to cast iron 4-bolt caps. Not as strong as the nodular iron caps.
