Old 12-30-2011, 08:46 PM   #1
lowrodderchev
lowrodderchev's Avatar
73 k5 half cab?
hey guys i have a question for you. im looking to get a older blazer and my neighbor happens to have one. he swears up and down its a 1973 but it has the half cab. i was told that chevy didnt make half cab blazers till 1975. is this true or maybe my neighbor has the wrong paper work on the truck.
lowrodderchev is offline   Reply With Quote
Old 12-30-2011, 10:49 PM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: 73 k5 half cab?
73-75 were full convertibles while the 76-91's were back half convertibles only.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 12-31-2011, 04:45 PM   #3
68Timber
I know the pieces fit
68Timber's Avatar
Re: 73 k5 half cab?
That's the way the factory made them, but guys have been swapping them around for years. Seems like most want to go from half-cab to full-vert, though. But if the truck is indeed a half-cab '73, someone put the half-cab on at some point.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-20-2012, 04:17 PM   #4
joaephdp
Re: 73 k5 half cab?
Yes, it's true. I have a 1973 half cab Blazer Joaephdp
joaephdp is offline   Reply With Quote
Old 01-20-2012, 06:56 PM   #5
lowrodderchev
Re: 73 k5 half cab?
shoot maybe i'll buy it off of him after all. i like the half cabs but dont want to deal with smog on them thanx guys
Old 02-02-2012, 11:34 AM   #6
Berg
Re: 73 k5 half cab?
Since you are in Cali I'd guess its either a re-body or more likely a tag job. When I was parting out my 75 I got more calls for the body plate with the title more than anything else! All the guys were from California. One of them told me its the only way he could get his 78 Blazer to not have to pass smog tests without having a cat or air injection or anything like that on it. If you really know the earlier trucks well and dig deep you could figure out what year the truck is as long as a lot of stuff hasn't been swapped out but you never know on something that old. A good check would be the fuse block. See if it came with a resistor wire on the engine side of the harness and see if it has been changed. If the truck now has an HEI distributor they couldn't feed it with less than 12 volts so they'd have to get the ignition hot source from somewhere else or open up the harness and bypass the wire. I'd say about 98% of people abandon the wire in-place and about 15% use the wire to trigger a Bosch-type relay getting its power from the battery or the junction block on the firewall. If it has the original gauge cluster it will have an Ammeter, not a voltmeter. It should also have glass fuses on the fuse block. GM didn't start going to the plastic style ATO fuses until somewhere around 1978. Another check is does it have a round filler hole for the fuel neck or does it have a square? That and don't forget the floor drop-off. 73-76 had the full rear floor right to the back of the front seats while the 77-91's had a step down for the rear seat so tall people would have foot room. 77-up also had the hinges on the rear seats that let them tilt forward and all earlier ones used bolts at all corners to hold them in if I remember correctly.
1970 Chevelle SS396
1984 K5 Blazer -First Truck!
1999 Big Block K2500 'Burb
Berg is offline   Reply With Quote
Old 02-02-2012, 11:48 AM   #7
Keith Seymore
Keith Seymore's Avatar
Re: 73 k5 half cab?
If you can find it you should be able to check the VIN on the frame as well.
Top of the frame rail, driver's side (I think) about midway back.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-03-2012, 09:07 AM   #8
Berg
Re: 73 k5 half cab?
Another way is to check the axles if it is 4x4. 73 to early 76 used a smaller spindle on the front axle and had a Dana 44 with the flat top passenger side knuckle. Trucks built 77-later came with a Corporate 10 bolt front axle. It should also have a 12 bolt truck rearend instead of a 10 bolt. The same goes for 2wd rearends. The problem with axles is they are so easily swapped over the years. There were different grille styles but obviously you can almost never go by that since they are so easily swapped also. best thing to do is find the hidden VIN numbers. If it has the original engine and transmission the stampings / tags on them should also contain a partial VIN.
1970 Chevelle SS396
