Brake bleeding tips
For those of you that are bleeding brakes and are having trouble getting them started, grab your favorite color balloon, or condom ( for those that have-not been cut ) place it over your shop vac, and place over the bleeder valve, I saw it for the first time today and it worked great, they hit all four wheel cylinders in about a minute, finished up with a manual pump ( foot ) and was done in ten minutes total. Note ( not responsible for the impromptu looks from your other half )
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Re: Brake bleeding tips
LOST HOPE on glens computer .............really? i just finished replacing brake shoes and cylinders and need to bleed mine ill try it if it really works?
#4 | |
![]() Join Date: Oct 2009
huh? That conversation sure took a hard left....
Thanks for the tip Rich! |
#6 | |
I hate to seem dense but Im having a hard time picturing this. I place a balloon over my shop vac? Then I place the same balloon over my bleeder valve? And that is supposed to do something? Like bleed my brakes? Am I missing something? Is this some sort of inside joke? I dont get it.
I could use a few tips on bleeding my brakes though, since it sometimes gives me problems. Doing all four wheels in under a minute sounds way too good to be true. Or am I missing the joke? |
The condom will wrap itself around the bleeder valve if held just right, then it will draw itself into the vaccum drawing te fluid down into the lines, the condom is jusst to keep from drawing everything into the vaccum, I guess you could do the same wit an old tire pump just be reversing the valving in it or any kind of vaccum device for that matter, you could make one out of pvc pipe by sleaving two together with a line to put right over the bleeder valve and drawing the inside sleave out thereby sucking the fluid down to the wheel cylinder.
what i wound up doing was was taking a garden sprayer with a small nozzle on the end of the hose and just filling the brake lines then reconnecting them to the m/c and well it didnt take me a minute but it took me less than 10
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
#10 | |
Keith |
