Fuel pump push rod question...
I got this truck a month ago. Fixed quite a few things, but I had an oil leak I couldn't pinpoint. It's been a while since I had an older vehicle. I wanted to check the block to see what engine it is, the smog pump was in the way, so I removed it(emission exempt in this county). The bracket was connected by 2 bolts on the front of the block by the fuel pump.I drove it 10 miles and blew half the oil out this morning. If I remember.....there is a bolt hole to run a bolt through to hold the fuel pump rod in place while changing the pump. I blocked them off now, I wouldn't have thought one of those smog pump bolts blocked that?????? BTW, the "350" is really a 305.......It'll get a 383 soon anyways.
THE DEVIL MADE ME DO IT! |
Re: Fuel pump push rod question...
That's pretty common. I had the same problem on the original 350 I rebuilt in my '69 Camaro. I put a short bolt with a copper washer and it never leaked again.
Larry 1972 Chevy C20 Custom Camper 1968 Chevy Camaro RS 1980 GMC K5 Sierra Classic |
![]() Join Date: Apr 2009
X2 on the bolt in the block, I have also seen a mystery oil leak that came out of the small vent hole on the fuel pump itself.
Desert |
