Old 12-31-2011, 03:46 AM   #1
KBoz
KBoz's Avatar
ls swap im my 61 apache
im having clearance issues with my exhaust manifold because i raised my crossmember up. i now i can use vette manifolds but im not sure what will work better? its a LS 4.8 L motor out of a silverado
KBoz is offline   Reply With Quote
Old 12-31-2011, 10:28 AM   #2
Crash_OK
Crash_OK's Avatar
Re: ls swap im my 61 apache
From the research that I have done a set of Trail blazer SS manifolds would work for you.. My truck is a 72, but the pistures you posted look very much like mine... Hope this helps.
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 12-31-2011, 10:36 AM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
I'll second the TBSS manifolds. Or are the 63 frames narrower then the 67-72?
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 12-31-2011, 12:55 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
x3 on tbss, check my build, i squeezed them in my '66 next to a 4l80e
I've heard the new camaro headers fight tight to the block, but the issue is the angle of the output.
The tbss manifolds have output flanges that tuck pretty close to the block, and clearance the perches and frame.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-31-2011, 04:20 PM   #5
KBoz
KBoz's Avatar
Ok Kool thanks.and I don't think it's narrower but I did raise my crossmember to clear the ground .one plus is I can keep the ax compressor in the factory location
1961 Chevy Apache 4.8L/4l60e with gmc grill
1998 Chevy Silverado 3/5 drop also with gmc grill
