Old 12-31-2011, 10:45 AM   #1
biohazardbill
Suburban Door Swap
We are thinking of going from clam shell to barn doors on the burban. Looking at the rear jambs it looks like all I may need are the doors and hinges and should bolt right in, is there anything I am missing? Will any barn doors from 60-66 work on the 65?
biohazardbill is offline   Reply With Quote
Old 12-31-2011, 02:19 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Suburban Door Swap
Pretty sure they are all interchangeable if you have the doors and correct hinges and latches. Be sure to hang on to those clam shells though, they are worth $$.
Old 01-01-2012, 01:34 AM   #3
Captainfab
60-66 Nut
As far as I know all you need is the '60-'66 cargo doors with hinges and the latches, and it should all bolt up. Although, you will have the notches in the tailpan where the tailgate hinges were. If you don't have the cargo doors already, you should be able to find some easily since most guys want the tailgate and hatch. In fact member Nobby is in the process of converting his from cargo doors to a tailgate and hatch. He has a build thread in the 'Projects and Builds' section.
Old 01-01-2012, 02:18 AM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
My father in law did this swap on his 1960 Chevy Carryall back in the early 70’s. He hated the tailgate arrangement because it was the family car and made it difficult to load groceries. He had very limited mechanical skills but installed the barn doors without any problems in one afternoon. He just picked up the doors and hardware at the junkyard, brought them home and bolted them on. I can’t relay any technical details, but it must have been relatively easy or he would have completely hacked up the truck (probably with a torch) to make it work.
Old 01-01-2012, 09:46 AM   #5
dthela
dthela's Avatar
the notches in the tailpan get the plastic fillers you take off the hinge holes on the sides.
dthela is offline   Reply With Quote
Old 01-01-2012, 08:27 PM   #6
Nobby
Nobby's Avatar
Hey Bio,Look in the 66 parts section and search barns doors.I have everything you need.
Nobby is offline   Reply With Quote
Old 01-01-2012, 08:33 PM   #7
biohazardbill
PM me your number.
