Old 04-23-2003, 11:31 PM   #1
oli
Question alignment specs
I have recently lowered my truck 3 1/2 and 5 inchs and I am looking for alignment specs for the truck. the truck is a 1968 chevy truck 2wd with coil rear suspension. Thanks
oli is offline   Reply With Quote
Old 04-24-2003, 05:22 PM   #2
Frank_Zeller
Frank_Zeller's Avatar
Below is info I got from off the board. Bias ply tires like negative caster. If your running radials go for positive caster. Should be similar spec to a late 70's truck.
"You can go up to 3/4 negative camber without worrying about uneven tire wear. If you have power steering, go for as much positve caster as possibe"
"I don't know the factory specs, but they suck anyway. I would go with -1/2 degree camber and as much positive caster as possible. Toe at 1/16 - 1/8 in"
"When I cut the coils on mine I had it realigned to a handling spec, go for half a degree negative camber and 3 degrees caster"
Frank
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
