Jaguar XJ gauges in my GMC
I snagged these gauges for 96 bucks along with the mounting bracket (less than a single autometer) and welded in the bracket today, what do you guys
Its even got a 6 cyl label on the tach and I have a 250, Thought that was pretty cool does anyone know what each wire is on the round stock connector? Ive got the jag side figured out but not on the gmc side any help would be great so i can get these things hooked up and working I was thinking about cutting out the center of my stock cluster and sandwiching it between the metal bracket and a faceplate that i have yet to make. any advice/ideas on making up the difference between the gauge face and the bracket? |
Re: Jaguar XJ gauges in my GMC
I have no idea why everything is upside down. Its right side up on my computer
You computer monitor is upside down = p
I like 'em. Posted via Mobile Device
X24 1964 chevy c10 step side 230ci straight six Auto power glide |
right side up photos
i give up. i inverted the photos and then uploaded and they showed up inverted. i uploaded right side up, and they show up inverted.
all you have to do is turn your monitor upside down, so far thats the only way to fix it ![]() |
![]() Join Date: Jul 2010
Tha assist,,
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
haha that looks better, backwards but better!
Thank you kind sir! |
Look at the bright side though, you'll never have to put gas in and the gauge will always say full! Cool gauges!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
maybe Jag is positive to ground and you have them now neg to ground. Maybe that is why they may be backwards.
ron |
no thats just some photo effects from flipping the pic. notice how it reads mpr and hpm.
My gas gauge reads full as soon as I turn it on? I checked the grounds, they all looked good and my stock gauge worked just fine. Could the impedance be different? If so could I buy/make my sender work with the gauge?
Posted via Mobile Device |
I've got all the gauges working except for the oil pressure, which I believe I need a different wiring or sender? Any input would be great
and the temp gauge, the stock one never worked so I'm clueless. If any electrical genius could help I'd be much appreciative and invite you over for beer and beef! Posted via Mobile Device |
#13 |
flipped and flopped
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#14 |
Thank you slow! Finally! That's what it actually looks like.
#15 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
In order for those gauges to work correctly, you are going to have to use the Jaguar senders, including the gas gauge sender. Unless of course Jaguar happens to use a 0-30 ohms sender for their gas gauge.....doubtful though.
