64-66 engines and trans for sale
I am open to offers,I may can help with partial delivery as well.I was doing some cleaning up and dismantled some of my parts trucks and hope someone can use this stuff,if you have any questions please ask.
![]() ![]() ![]() very good running engine,was in truck yard driving on 12-28-11 numbers show a 230/250 not sure which,trans. not included.$250 ![]() ![]() 283 w/3 speed manual,engine was smoking a little but was being driven.$375 for both. ![]() 3 speed manual,trans only no bellhousing.$90 If there is something you are interested in let me know I am open,Thanks for looking. Jay Last edited by jhrusk; 01-14-2012 at 11:02 PM. |
![]() Join Date: Jun 2007
Re: 64-66 engines and trans for sale
How much for the complete 283 w/ no trans and no bellhousing? Has it been rained in? looks to only have tape or something across the intake and dist holes?
GMCNUT the suffix code is FI208WA,I am pretty sure the engine has not been rained in,although it has been outside the top portion has always been covered,I removed the plugs and the engine spins over freely so I dont think any water has gotten into it.If you buy it I think we could stab an HEI in it and a carb and fire it off in the shop.I could do $275 on the engine without the trans,just keep in mind you will get what is in the pic(not the HEI and carb)Hope this helps. Jay
Cool - do you have the original carb or same Rochester 2 Jet that came on it? the pics look like it might have a 4 bbl intake? supposed to be a 2bbl....I'd want to exchange the 4 bbl for a correct 2 bbl intake if that was an option....
is the trans with the 6 an overdrive and would you sell the overdrive?
Pm me, i tend to forget. Thanks, Steve |
GMCNUT it does have the original 2-barrel intake.it had a holley 2 barrel on it when I got it.what you see in the pic is an adapter plate for a Holley.
qksilver,yes the trans in the pic is an overdrive but I am saving it for my restoration,sorry.I do have 2 standard 3-speeds.Thanks for looking. Jay |
so do I! the trans that is............
If you change your mind let me know. Thanks, steve |
i am open to offers.Thanks
on the overdrive? lol........will be in Atlanta the first of Feb.
Steve |
I would be very interested in the 230/250 if I was any closer to you. You wouldn't happen to be coming west any time in the near future?
Lovin' my 64 GMC Fleetside Daily Driver |
Ill have to hang on to the OD qksilver,rbuckin111 I dont have any plans to head west,sorry.Thanks guys for looking.
ttt
#13 |
is the 230/250 still available? I could probably be there next weekend
#14 |
would you sell the shift linkages for a 3 on the tree? Mine is sitting behind a 230 if it makes a difference.
#15 |
c10hevy I do still have the engine available,next Fri or Sun would be OK I will be out of town on Sat.
kenmel I will sell the linkages,I will have to check and see if there are any differences between the the 6-cylinder and rhe V-8.give me a day or two and I will let you know.Thanks. |
#16 |
Thanks jhrusk, I would need all the bolts and the clamps (or whatever they are called lol) that attached to the trans and bolts for the column. All my stock parts were removed when the PO put in the cheap floor shift. lol
#17 |
would you sell the linkage off of the 3spd behind the 6cyl in the pic? or is that the one with overdrive? Thanks Ken
#18 |
the linkage behind the 6 cyl is the od trans,I am going to compare it to the other set of linkages I have behind the 283.do you know if your trans is a syncronized 3sp or the standard?
#19 |
All I know is it is a 64 c10 with a 230 and 3spd lol. here are some pics if that helps.
#20 |
give me a few days and I will look and see if I have everything you need,I think I do but I want to put my hands on it.
#21 |
would you sell the spark plug wire looms and the heat shields around the plugs? Trying to make my 327 look factory.........
Pm me, I tend to forget. Thanks, Steve |
#22 |
kenmel I have everything except one adjuster that goes on the column,I plan on going to a pull-a-part on thursday and I will look for the other piece.I was thinking $50 plus shipping.let me know.
qksilver I have all the looms and only one heat shield.$25 plus shipping.let me know. Thanks guys for looking. |
#23 |
I will let you know Tuesday........I am going thru all my boxes and see what I come up short with.
Thanks, Steve |
#24 |
I haven't been able to get out to the shop yet, probably won't be until Thursday, my day off.
Thanks, Steve |
#25 |
just wondering if you found the other adjuster ? if so 50 would work. shipping to 72150 Thanks Ken
