Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 01-01-2012, 02:53 AM   #1
69C-owner
how to wire up a 1995 140Amp alternator on a 69
I already have aninternally regulated alternator wired up and charging but the newer alternator is good and just laying in my "spare parts" pile so a swap would be cool if anyone can help, the alternator came off of a buick roadmaster, LT1 car
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet
1994 Buick Roadmaster
1994 GMC Sonoma
69C-owner is offline   Reply With Quote
Old 01-02-2012, 12:57 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: how to wire up a 1995 140Amp alternator on a 69
Have a look here.
http://temp.corvetteforum.net/c3/zma...ternator01.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-02-2012, 06:37 PM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Keep an eye on the wiring, the red wire that goes across to the battery, if you use the 140 amp make sure the wire doesnt get really hot.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 01-03-2012, 10:40 PM   #4
Street Smart
Street Smart's Avatar
Smitty
true, can`t hurt to run a heavier wire.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 03-02-2012, 12:33 AM   #5
69C-owner
Ttt
1994 GMC Sonoma
Old 03-03-2012, 02:13 AM   #6
storm9c1
*** That's interesting ***
storm9c1's Avatar
What do you want to know that wasn't already in that article that VetteVet posted? There is tons of information here about swapping alternators if you poke around. The biggest issue is the regulator mod. The LT1 140A is a really good alt, but it will be configured for a serp and you need a V-belt pulley for your '69. I'd be curious too if there is an easy way to do that.............
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 03-06-2012, 11:58 PM   #7
69C-owner
im sure I can swap the pulleys and I already have an internally regulated alternator wired up and charging, I need to reread thru that article on an off day when my mind isnt fried lol
1994 GMC Sonoma
Old 03-07-2012, 12:45 AM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
A single V belt may not be enough to drive a 140 amp alt. You may need to convert to a dual V belt or Serp setup
dwcsr is offline   Reply With Quote
Old 03-07-2012, 02:13 AM   #9
MalibuSSwagon
I have the SI series on my 86, running a ribbed pulley. Now should I swap over the pulley and fan or just the pulley? My alternator mounts on the right (passenger) side of the engine.
This thread made me do a little research and I realized that the stock 42 amp alternator will not be enough with the TPI conversion, it was barely enough before!
MalibuSSwagon is offline   Reply With Quote
Old 03-09-2012, 07:18 PM   #10
jhngardner367
jhngardner367's Avatar
Changing the pulleys is easy.Just make sure you use the spacer that was with the original pulley.
Also,I just put a 105amp alt on my '85,and still used the v-pulley,with no problems.I used the alt from a '94 Grand Am. I did have to make a top mount/adjuster,but it works.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
