heater switches or blank out
i have a 56 military 1/2ton and it dont have heater switches has the blank out ,,i was wondering i found a heater unit to put in it ,but what did they have for a switch if it didnt come with the heater controls ? mine just had a on off switch hanging on the floor and i flip a lever on heater for defrost to heat ? and i looked in pics and googled and still never seen a heater on off switch ?
Hollister Road Co.
Re: heater switches or blank out
The factory "Deluxe " heater had a dash control with cables to operate the venting. Aftermarket units usually were manually operated with either a switch mounted under the dash or a switch mounted in the factory heater control blank
Post a picture of what you have. |
This type was used as an aftermarket, clamps to bottom of dash,or you can drill a hole in the block off plate. Some types had a bulb inside that lit up when on. Under 20 bucks, do a google search for heater switch.
Retired and too busy to work. |
The factory one is about 200 and you need the cables as well.
The standard heater had a single knob switch in the blank out plate. Deluxe had the three lever type.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
the top pic is what the dash looks like now in my delete plate i didnt have a hole for a switch but i found a 55 panel at a junk yard and it has two switches on a factory plate that mounts between the vent knobs ,,im gonna get it tomarrow and i picked up a delux heater control from it yesturday , and it all works only missing one knob
#8 | |
You can get used ones that need restored pretty cheap. I have the original standard heater with the switch in the plate. If your interested, PM me.
it looks dirty than it is not as bad pitted i havent cleaned it yet ,,,just wondering to leave factory or add the heater controls
it was originally grey the inside i had the body guy paint it in primer so it would be ready for paint all i got wa a dp90 over coat that cost me 400 bucks hahhaa ..
I think I have some extra cables, will look if you are interested.
#13 |
I think you can see the delux one in there, I have it converted for AC
#14 |
http://www.scribd.com/full/75817434?...ekaw0jyon6pa1h
page 29 go by the blue page numbers also parts for old ones |
#15 |
![]() Join Date: Aug 2010
The Filling Station sells the levers,knobs, cables etc. check them out at http://www.fillingstation.com
