Frame rivets
i was at the pick a part .i got the sway bar and what unbolts.that left two rivets.at home i would use a air powered cut off tool.i need ideas on how to did it in junk yard.i tried a hammer and chisel but they are tough.thanks
Newbee
Re: Frame rivets
Center punch, and drill, then chisel. Large hammer, and a drift punch to knock em out.
Re: Frame rivets
torch or 4 in grinder and a generator. other than that, you will have to buy the frame perches ( I am assuming that is what you had to leave behind ). if you dont have either find a buddy that does and both of you go and make a day of it.
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
![]() Join Date: Mar 2005
Re: Frame rivets
If you have intentions of lowering the truck, I would highly suggest the lower profile mounts that places like Classic, the Truck Shop, and Brothers carry. If it's going to stay at stock height, they carry those, too. If I recall, they are around $15 for the pair, bolts included.
Most self-service yards around here won't allow torches or power tools.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
