01-01-2012, 11:58 AM | #1 |
Hubcaps
Does anybody have pictures and diminsions of hubcaps that should be on a 1965 3/4 ton 4x4 long bed stepside?
01-01-2012, 12:04 PM | #2 |
Re: Hubcaps
the truck is currently running 8"x16" rims
01-02-2012, 12:51 PM | #3 |
Re: Hubcaps
Here are some older pics of the truck before i sent it away.
01-04-2012, 02:39 AM | #4 |
Re: Hubcaps
1960-66 4x4 trucks did not have hubcaps installed on them when new.they just had rims only without hubcaps.
01-04-2012, 02:54 AM | #5 |
Re: Hubcaps
Thanks Collins I really think it would look better like that anyway.
Posted via Mobile Device |
01-06-2012, 02:54 PM | #6 |
Re: Hubcaps
Chevy did offer a 4x4 hubcap in 1963. Looks like the stock hubcap with a hole in the center. Don't see them very often, but they are around. There was 1 on ebay about a week ago. This is a pic of the rear cap for 3/4ton that had clips on the rims....have a pic of a 4x4 front with the hub hole...will try and find
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 01-06-2012 at 03:11 PM. |
01-06-2012, 03:11 PM | #7 |
Re: Hubcaps
Here are factory 64-66 4x4 hubcap
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
01-06-2012, 04:46 PM | #8 |
Re: Hubcaps
All the factory literature I've seen, 4x4s had no hubcaps from the factory. Anyone can easily cut some holes & install them, though.
01-06-2012, 04:52 PM | #9 |
Re: Hubcaps
Can I just say that I have never been a fan of longbeds or long steppers, but your truck has changed my opinion. That truck looks rugged as hell and I love it!
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
01-06-2012, 05:50 PM | #10 |
Re: Hubcaps
I have seen multiple 62-66 trucks with GM made 4x4 hubcaps in the last 20 yeasr. I do not dispute that it may not be found inliterature, but the ones I have seen were not modified. They were OEM parts. They may not have come stock, but could be ordered and do exist.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 06-10-2015 at 04:48 PM. |
01-06-2012, 07:16 PM | #11 |
Check The Champ, Demonstrator
Re: Hubcaps
1963 Chevrolet 4WD did not come with hubcaps from the factory. Since they were the same from 1961-63 in two wheel drive & 1962 4WD would have been the same, who says you couldn't order a set and put them on your truck! The GMC caps have that nice circle in them for machining out the center section for installing on the front diff.
READ THE LAST LINE ON THIS PAGE! Parts book shows no listing for a 4WD cap after 1962! Interesting! 1963c-10 Dinsmore supplied Chevrolet & GMC with a compass. 1963 Custom Features Accessory Book Are these the moldings your referring to? 16.475 Last edited by aerotruk63; 01-06-2012 at 09:48 PM. |
01-06-2012, 08:24 PM | #12 | |
Re: Hubcaps
nor the GMC fact A/C or buckets-but I've seen one w/it. Last edited by 64fleetside; 01-06-2012 at 08:30 PM. |
01-06-2012, 11:42 PM | #13 |
Re: Hubcaps
Many get caught up in the '60-'66 trap and make generalized statements. Features are year specific in most cases and you just can't clump these years together with the same rules. 1960 and 1961 Chevy 4X4's did come with hubcaps as standard equipment. 1962 thru 1966 Chevy 4X4's did not come with hubcaps as standard equipment. However, if you wished to install them on a '62-'66 back in the day, just visit the Parts Department and order a set and start cutting holes. IMO, a set of caps just looks more complete.
01-07-2012, 03:27 AM | #14 |
Re: Hubcaps
Does wheel size have any bearing on if the truck came with hubcaps? My 1961 GMC Suburban 4WD has 17.5" wheels. It was a pretty fancy and expensive truck when it was new. I can't imagine buying a truck this nice and expensive and not getting any hubcaps with it.
My Sub spent its life as a university geology department field vehicle driven by professors. I think they took some care of this truck and it contained details like owners manual and other literature in the glove box, along with hardware that fell off like sliding window latches. It wouldn't have surprised me that at least one hubcap remained if it originally had them. I don't think I've ever seen a photo of an early 60s GMC 4WD Suburban with 17.5 wheels with hubcaps. |
01-07-2012, 09:47 AM | #15 |
Re: Hubcaps
My 1962 K20 has 17" wheels, and all five rims have four tabs rivited to the wheels. The wheels are the same color as the truck. Are the 17" rims have the same size hubcaps as a 16" wheel?
01-07-2012, 12:24 PM | #16 |
Re: Hubcaps
Rim size has nothing to do with wondering if a hubcap will fit. The important thing is if your wheel has clips or not. If a 3/4 ton, only wheels with clips will attach orignal style hubcaps. 3/4 ton 8 lug clip rims require 8 3/4" opening hubcaps. If a 1/2 ton, wheels came with both clips and bumps. If you have bumps, you need the 10 1/4" opening hubcap. If your 1/2 ton has clips, you need the 7 5/8" opening hubcap.
01-07-2012, 12:47 PM | #17 |
Re: Hubcaps
Here is one. Gov. agencies typically ordered this optional wheel for higher ground clearance. These 6 lug 17.5" wheels are super hard to find today.
01-07-2012, 06:55 PM | #18 |
Re: Hubcaps
Heres another question. I hear a lot of trucks have 17.5s and other have 17s. Did the wheel combo vary at build plants or customer choice?
01-07-2012, 08:10 PM | #19 |
Re: Hubcaps
I think that if you could look at the bare bones basic truck it will be listed with a 17 0r 17 1/2" wheel. everything from there on was an optional tire. they would have been the cheapest tire and wheel that could be put on to do a job. very seldom would they ever be ordered that way
you would have seen them more on governmental vehicles or as a lost leader to get customers into the dealership. the price on this chevy truck this month is $1295.00; std truck 250 cu in eng, 3pd, 17" tires,no heater,no radio, 1 sun visor and single colour. ford and ihc perhaps couldn't get under 1350.00. that farmer thought that was a pretty good price for a new truck and away he would go. new truck for the farm . people hardly ever buy a basic truck any more. ron |
01-07-2012, 10:02 PM | #20 |
Re: Hubcaps
Its easy to get confused with 1/2 ton and 3/4 ton wheel sizes.Unfortuantely, sales brochure just list standard and maximum sizes, not the inbetween sizes. The 17.5" 1 piece wheel was available in both 6 lug 1/2 ton and 8 lug 3/4 ton. The 17" 6 lug 1/2 ton wheel does not exist. The 17" 8 lug 3/4 ton wheel was made, but only in a 3 piece heavy duty design.
01-07-2012, 10:33 PM | #21 |
Re: Hubcaps
then it will be the 17.5" wheel. most 1/2t would have been ordered with either 6.70 or 7;10 x 15" and most 3/4t would have been 7;50 x 16"
ron |
01-07-2012, 10:38 PM | #22 |
Re: Hubcaps
Isn't it great we've found nice folks who give a rip about crud like this like we do.
01-07-2012, 11:05 PM | #23 |
Re: Hubcaps
American GMC's had different rules where it came to fitting hubcaps on 4X4's.The latest year for GMC to use hubcaps on 4X4's was 1965.I will not comment on Canadian built GMC's, but only guess they followed Chevy by ending in 1961.Check out this 4X4 GMC with heavy duty 3 piece 15" rims.
01-09-2012, 10:07 AM | #24 |
Re: Hubcaps
I found all the factory numbers for 60-66 hubcaps, both painted and chrome....will bring in tomorrow. It list 15", 16" and 17" hubcaps 1/2ton, 3/4ton and 1ton. Also list a complete rim cover for I believe 1960 or 61. Im not saying that any 4x4 trucks came from the factory with hubcaps, Im just saying that they were manufactured.
01-09-2012, 10:41 AM | #25 |
Re: Hubcaps
To the original question,if it hasn't been answered yet. You won't find any original hubcaps to fit your wheels. Your wheels are later design. All 8-lug GM truck hubcaps through '68 mounted using internal clips.
