Old 01-01-2012, 07:00 PM   #1
1972RedNeck
1972RedNeck's Avatar
Amp Guage
I have a 1 wire Chevy alternator on my truck. Is there any way to hook the amp gauge up?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 01-02-2012, 09:12 AM   #2
1972RedNeck
Re: Amp Guage
Yes? No?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 01-02-2012, 10:11 AM   #3
JimKshortstep4x4
Re: Amp Guage
Do you have a stock wiring harness with the stock ammeter and have you added or changed any of the power wires from the ammeter to the battery?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-02-2012, 10:15 AM   #4
shawno72
C/10 junkie
shawno72's Avatar
Re: Amp Guage
My father in law changed his alternator to a one wire and his gauge works fine on his 70 gmc. His truck has the factory gauges.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 01-02-2012, 08:05 PM   #5
1972RedNeck
Re: Amp Guage
I just hooked up the red wire to the terminal on the back of the alternator. Everything else is stock. I just taped off the other two wire.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 01-02-2012, 08:25 PM   #6
Andy4639
Old member
Andy4639's Avatar
Wink Re: Amp Guage
The factory amp meter is a good guess at best. Even if it's working it's hard to tell what it's doing.
Why not buy a volt meter and hook it up?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-02-2012, 08:56 PM   #7
1972RedNeck
Re: Amp Guage
I know they're hard to tell if they're working but I'm pretty sure mines not.
I am going to get a volt gauge along with some others. I want everything my truck has to work though.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 01-02-2012, 09:22 PM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Amp Guage
If your truck is wired like the diagram below then the ammeter should work just fine. You can eliminate the voltage regulator, switch alternators and run the red wire off the back of the one-wire like it shows in the diagram. If you run it to the battery plus cable or the starter then the ammeter cannot read the voltage differential between the battery and the alternator. The one wire alternators will eliminate the battery charging light from the circuit. It's so easy to use the three wire alternators that I don't recommend the one wires.
You will need the small 20 gage black wires and the fuses for the ammeter to work.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-13-2012, 05:24 PM   #9
_Ogre
_Ogre's Avatar
Re: Amp Guage
redneck
your old amp gauge is 30 amp, your one wire alternator is probably 100 amps.
i'm not a fan of running 100 amps thru a 300 amp gauge with old wire.
most oem's got rid of amp gauges in the mid 60s, dodge was the exception.
i feed my alternator directly to the starter cable, but like you i want all my gauges to work.
follow the link in my signature to see how i converted my 58 truk's amp gauge to a volt gauge.
it's fairly easy to convert the gauge.
shop air compressor timer
