Old 01-01-2012, 08:25 PM   #1
cfan10
cfan10's Avatar
Cool Dual tanks, advice from the savvy
How to use both tanks again, ex-mechanic did something to the switch, (electrical) it gets no power. No noise when switching. Bolt in cut-down hose on switching valve, is it possible that mechanic installed switch valve wrong? Because it didn't work right, as it would shut off. This is why he switched to one tank. Brand new switching valve.
Everything worked fine when I bought the truck, all this bs just wanting gas gauge to work, it acted more like a clock. And still doesn't work. I'm tired of wasting gas due to overflow from tank.
Any advice or experience on what to do, I want to use both tanks again.
How far does switch button wires run, and where are they supposed to go (connect to)
As always many thanks for your help. It is most sincerely appreciated.
cfan10 is offline   Reply With Quote
Old 01-01-2012, 09:36 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: Dual tanks, advice from the savvy
What year is your truck? There are two different systems between 73 & 91.
Old 01-02-2012, 12:11 AM   #3
pig rig
pig rig's Avatar
the easy way to tell witch switch you need is if your truck is a TBI truck or not the TBI switch also powers up the fuel pump
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 01-02-2012, 04:19 AM   #4
cfan10
cfan10's Avatar
84 swb
305 cid
Old 01-02-2012, 05:38 PM   #5
beamn7
From the 1984 GM manual....
Seems the editor that day was napping as both tanks were labeled "left tank". Best verify tanks by wire color....
beamn7 is offline   Reply With Quote
Old 01-02-2012, 10:32 PM   #6
hatzie
Moderator
hatzie's Avatar
The switch and selector valve are the same. The TBI tank wiring harness is different to feed power to the pumps.
Old 01-02-2012, 11:14 PM   #7
hatzie
Moderator
hatzie's Avatar
I attached the Dual Tank Parts Book Illustration pages and the NL2 Dual Tank wiring schematic.
Hopefully these will help you sort out what's wrong.
File Type: pdf NL2_DUAL_TANK_ILLUSTRATION_1979_1984.pdf (87.2 KB, 118 views)
Old 01-03-2012, 08:07 AM   #8
donut
donut's Avatar
Thanks for posting those hatzie, I'll be doing the "get my dual tank to work" thing soon.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
