Old 01-02-2012, 01:41 PM   #1
69trk
69trk's Avatar
what tranny should i go with for turbo ls build
should i go with a 4l80e, or a turbo 400 with 3:23 gears?
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 01-02-2012, 02:33 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: what tranny should i go with for turbo ls build
the 4l80e is going to give you the same level of strength, with the bonus of overdrive and computer control (and if you'r running an ls, its almost easier just to run the o/d trans).
4l80e
1 2 3 4 R
2.48 1.48 1.00 0.75 2.07
thm400
First Gear - 2.48 to 1.00
Second Gear - 1.48 to 1.00
Third Gear - 1.00 to 1.00
Reverse - 2.07 to 1.00
essentially the same gearing.
you can run a higher rear gear to pep it up, and let the o/d keep the rev's down on the highway.
with 3:23 rear end you would be smooth as a caddy on the freeway with a 4l80e
what rear end are you running? The 3;23 was much less common in truck.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-02-2012, 02:44 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
What BR3W said!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-02-2012, 04:24 PM   #4
69trk
69trk's Avatar
thanks, 4l80e it is!!! The rearend that i have now is truck 12bolt with moser 33spline axles and a full spool and 3:73's.
1.58- 60'
11.37- 1/4 @115.81
Old 01-02-2012, 04:25 PM   #5
69trk
69trk's Avatar
4l80e
1 2 3 4 R
thm400
Where did you get your 4l80?
1.58- 60'
11.37- 1/4 @115.81
Old 01-02-2012, 06:01 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
same exact setup as me! 5 lug truck 12 bolt with mosers and 3:73 nice.
I got my 4l80e off of craigslist. I found a kid who stripped cars in his backyard and JUST found a 96 2wd 2500 truck that he was selling for parts. I offered him $300 for the running trans and picked it up later that day. The price wasn't bad even if it ended up being a core, but it worked. I had her built anyway tho.
Old 01-02-2012, 06:05 PM   #7
69trk
69trk's Avatar
how much do you have in the build of your trans? How did you get speedometer to work? thanks
1.58- 60'
11.37- 1/4 @115.81
Old 01-02-2012, 09:52 PM   #8
69trk
69trk's Avatar
I found a 4l80e trans for $80. I plan on rebuilding to handle the power. My question is that this trans came out of a box truck with a drum mounted on the tailshaft. Will this trans still work? thanks
1.58- 60'
11.37- 1/4 @115.81
Old 01-02-2012, 10:42 PM   #9
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
$80! I don't care what it is, it would be mine Coming out of a box truck though, I think it may be a 4L85E with straight cut planetary gears....noisy.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-02-2012, 11:19 PM   #10
69trk
69trk's Avatar
it has a stamping on it that says it's a 4l80e
1.58- 60'
11.37- 1/4 @115.81
Old 01-03-2012, 11:32 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
is the drum for a pto or something? no idea what thats about.
For $80 at worst you'd have to swap out the tailshaft, no biggie if your already gonna build the trans up.
I had my trans built with all new insides,seals, springs etc and a hd lockup converter (28 or 3200 rpm I can't remember) for about $1500ish.
The converter was actually spec'd based on future nitrous use, but I might not actually go that direction. I was told in conversation that the setup should be good to close to 800hp without grenading.
