Steering wheel turns?
How many times does the steering wheel turn before it hits the steering stop?
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Steering wheel turns?
Anyone?
It feels like a hundred. My replacement box is 3 turns lock to lock
Posted via Mobile Device |
For which model?
It varies by 2wd vs 4wd, series, steering gear ratio and tire size (in some cases). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Thanks men. I have an 87. When my wheel is straight it turns one and one half turns , and then stops. The PO cut the steering stops off. The truck is lowered so the wheel is cutting into the control arm. I'm making steering stops for the control arms. Then the steering wheel will turn about one and one fourth and then stop. Then the wheel won't hit the control arm. At least that is the plan.
Yes, 1.5 turns from center should be about right. Don't make it too short so you have to do 8 point turns.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
