Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
64-66 wheelbase lengths?
I have a 65 shortbox fleet side chassis ready to roll.....does anything else bolt on?...I saw a short panel once that looked like it might ? I couldn't find any imformation on what might swap over so i thought i would ask and see if anyone here knew if it did
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[ 1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123 1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909 1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625 Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic Aluinum Radiator Dealer pm for details |
Re: 64-66 wheelbase lengths?
A panel truck or suburban have the same wheel base but have different body mounts.
Thanks.....I thought that might have been the case.....would have been way too easy if they just swaped out bodies on the same frame
1961 crewcab
the differences are pretty minor, should not be too hard to put a panel/suburban, or even a early cab on it...just a little mount work .
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
I wish i had one to compare too .......i like the idea of bolting a short panel onto it...would make a great tow vechile for my prostreet truck
1961 crewcab
from the visual on mine, the major differences were that the rear "cab" mounts were smaller, and narrower, but they look to be in the same spot, the front "cab " mounts are the same ( with the 60-62-vs-63-66 width difference taken into consideration) the rear of the sub frame has a slight dip, and some bumper mounts on it. , the dip is to clear the rear tail pan. I would guess that if you find a panel/sub body, you will get a frame with it... shouldnt be too hard to transfer over whatever you need.
here is a pic of Dinos bare sub frame that might help...
![]() Join Date: Aug 2008
I'm pretty sure you have to pull of your front pair of bed mount brackets from the frame if you put a panel body on it.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Also note that in addition to the body mounts, the rear frame horns are different from a pickup, to accomodate the tailpan and rear bumper of the Suburban/Panel. There is another member here that put a Suburban body on his C10 chassis......just can't think of his name ATM......
It always amazes me at how much you guy's know......this is alot of help thanks for taking the time to post
