What did you do ?new brake master cyl
how did you all or any fill your newer style brake master cylinder if you changed to the newer chevy style disc brakes or power brakes and left the stock under frame location ? i wcut a small hole and cringed in floor but you cant get to it with seat installed
#2 | |
Re: What did you do ?new brake master cyl
www.scottshotrods.com 805 485-0382 If you have some questions please ask or e-mail me and I can e-mail you over some pictures Justin |
#3 | |
Elev8r Man
1955.2 C4 Carry-all / Suburban ![]() 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
yeah cause i went to refill it and its a pain using a funnel with a hose on it under the seat ,,
I built my own brake MC/booster bracket and moved it back so the top clears the first raised cross brace. I then made a door above the MC lid. I fabbed my seat brackets so the original tilt feature works to gain access to the door and other stuff I will have under the seats (stereo stuff). If your seats are fixed then it will be a challenge, and a remote fill set up might be the way to go. I would be worried about the line cracking or breaking and compromising the brake system.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
![]() Join Date: Jul 2007
I just crawl under the truck, pop the lid and use a squeeze bottle with a short plastic hose on it to fill the master cylinder. I guess a guy could glue a mirror to the floorboard so he could see the fluid level but I haven't gone that far yet.
yeah i have stock seat in it now i have a pair of buckets ,,i could build a tilt for the driver side if i use them older schreels ,from a bmw nice seats , and for the remote system i thought about that and wonderd also on how the rubber hose would be as long as kept it fresh .
Yellow truck club
I also just went under with squeeze bottle with a short length of tubing on it.
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
i have a hole like orrieg i will make a little trap door ,unless i use the bucket seats i have
![]() Last edited by JumboAMONGus; 01-04-2012 at 01:54 AM. Reason: picture didnt show up |
