01-02-2012, 07:26 PM | #1 |
modify or ditch it ????
anyone modify one of these rear brake load porportioning valves for lift ???
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
01-02-2012, 09:21 PM | #2 |
Re: modify or ditch it ????
That is one of the earlies attempts at rear anti-lock brakes. My '86 K30 has same. You could build a drop bracket for it, but I would be tempted to eliminate it. Will make running dual exhaust a lot easier...
01-02-2012, 09:35 PM | #3 |
I do want to run dual exhaust so maybe it will have to go
01-03-2012, 12:07 AM | #4 |
Ditch it!
CHEVY ONLY |
01-03-2012, 09:17 PM | #5 |
I ran my own exhaust, and as for now, the shock on that side is out because either it had to go or the brake stuff. Probably should of killed the brake stuff on mine, but it is just a farm truck.
01-03-2012, 09:29 PM | #6 |
Kid's Mechanic
Those were a pain , company trucks were a constant complaint . Finally bypassed all of them and got rid of those valves ...And the complaints
01-03-2012, 09:34 PM | #7 |
its kinda of a cool....the more weight you load in the bed the more rear braking powr u have, but after pouring money into this truck i wont be using it to haul wood or hay or anything like that and my camp trailor has its own brakes so I,ll probably get rid of it
01-03-2012, 10:52 PM | #8 |
6>8 Plugless........
Most of the trucks I've owned or worked on that had those, they either leaked, or didn't work. I'd ditch it.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-03-2012, 10:56 PM | #9 |
Kid's Mechanic
The company trucks would get in trouble with the trailer type air compressors . In a panic stop it would take weight off the back and leave you without rear brakes
01-04-2012, 02:05 PM | #10 |
thanx for the feedback guys!!! i'll pull it off .....
01-04-2012, 03:07 PM | #11 |
you could always ditch the factory setup and go with an aftermarket unit. ..they're much smaller and you can locate them out of the way.
01-05-2012, 04:42 PM | #12 |
Registered 1971 K5
Thats just extra weight thats not needed in my eyes. Trash it.
01-14-2012, 01:42 PM | #13 |
Cool to see another K30 being saved! How bout some pics or a build thread?
Here's mine. I found it after a long search about 12 years ago. It was pretty clapped out as it was an old logging crummy from the east cascades. The underside had "can-opener" cuts in every concievable hole or corner from chain hooks. I've put a lot of work and parts into this thing over the years. As soon as I can find a decent bed and tailgaite, I'll squirt some paint on there (the original red). Bear in mind, this thing's purpose in life is still hard work. It's not ever going to be sweetheart.
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
01-14-2012, 01:43 PM | #14 |
01-14-2012, 04:47 PM | #15 | |
Cool truck!! Posted via Mobile Device
CHEVY ONLY |
01-15-2012, 12:41 PM | #16 |
That'd be the little knuckle-head doing the driving. He'll be licensed next year if he can get is poop in a group at school. At that time we'll see if we can find him a Geo Metro
01-15-2012, 02:42 PM | #17 |
CHEVY ONLY |
