01-02-2012, 10:29 PM | #1 |
need help identifying these oil baths
I think one is for big chevy and one is for c-10.
01-03-2012, 02:05 AM | #2 |
60-66 Nut
Re: need help identifying these oil baths
The larger one does look like the one on my '63 C60 with a 292.
01-03-2012, 11:32 AM | #3 |
The small one def looks like a 2 5/8 for a model B Rochester 1bbl
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
01-03-2012, 01:03 PM | #4 |
The little guy closely resembles the one on my '62 3/4 ton. Rochester B on a 235 6cyl. I say closely because the step in my lid does not appear as pronounced as yours. ?
01-03-2012, 02:52 PM | #5 |
Just out of shear curiosity what were those for. I have 66 with 250 l6 and a single barrel rochester. Right now i just have one of those small round open sided filters on mine. should i be running something more like this oil bath or a larger breather type?
01-03-2012, 03:00 PM | #6 |
I believe the oil bath air cleaners we're the optional heavy duty cleaners for consistently dirty/dusty driving like on dirt roads.
01-03-2012, 03:36 PM | #7 |
I wonder if the bigger one breathes better. I am keeping one and selling the other, i just don't know which one yet. I'd like to keep it as stock as possible, are the bigger ones worth much?
01-03-2012, 04:15 PM | #8 |
This is the standard filter for the 230/250
01-03-2012, 05:14 PM | #9 |
Just here to tinker
I would say whichever fits and looks the most pleasing to you, go for it. I doubt that one flows better than the other. Oil bath filters theory is: as the air is drawn down into the opening, once it hits bottom (where the oil is) it is forced to make a 180 degree turn up and because dirt particles are heavier than air, they are trapped in the oil while the air makes the turn, goes through the filter media, and makes it into the carburetor. I'm pretty sure all filter media in the center piece is of the same type so I can't see how one would flow better than another. Just my .02.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
01-03-2012, 07:35 PM | #10 |
The larger one is from a car. It has silensing chambers. They flow the same like Corts says. I would use the smaller one. It looks more at home on a truck & hasnt got the extra weight hanging on the carb. It is worth more as the car ones are hard to sell.
01-03-2012, 10:29 PM | #11 | |
01-03-2012, 10:34 PM | #12 |
well I guess the next question is, "does anyone here have a carb for sale that came on a 60 chevy truck"? or can I change the top of my carb?
01-04-2012, 02:35 AM | #13 |
the larger one is for a 292/283. I have one on my 283 and my 292 that identical to yours. My 283 uses the original 2 barrel rochester.
01-04-2012, 03:38 AM | #14 | |
01-04-2012, 09:56 AM | #15 |
The oil bath air cleaner should work on your carb. It looks real close to the Rochester model B, just has a different fuel inlet, by the picture, but there were several variants to the carb. My model B feeds from the left (see pic) whereas yours and oem4me's model b's feed from the front. You might have to change the air cleaner rod to one that is the proper height for the oil bath cleaner, but with a 2 5/8" neck it should work.
