Old 01-03-2012, 01:36 AM   #1
masshole
steering column ideas......
I am at the point of my 1951 build where i need to decide on a steering column, I really want to keep it simple and keep the cost down so I can try to finish this thing someday soon. anybody make their own? pics would be great,thanks Greg
masshole is offline   Reply With Quote
Old 01-03-2012, 02:16 AM   #2
mr48chev
mr48chev's Avatar
Re: steering column ideas......
Simple would be the Column out of a 4 speed 70/72 if you are running a floor shift or the automatic column out of one if you want to run a column shift automatic. You would probably have to rework the steering shaft below the column a bit though in most cases as the shaft goes from the steering wheel down to a U joint a few inches below the end of the column.
The 80 something Chevy van columns that come on vans that had the ignition switch in the dash are popular because they are really clean and the tilt is one of the cleanest tilts around.
Old 01-03-2012, 08:32 AM   #3
masshole
i am running a t5 transmission, so a clutter free column is my goal. thanks again
Old 01-03-2012, 12:41 PM   #4
mknittle
mknittle's Avatar
I made my own using GM tilt parts super clean but not so simple.
I only have a couple bucks in parts in it.
http://67-72chevytrucks.com/vboard/s...d.php?t=474288
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 01-03-2012, 06:13 PM   #5
Red Foreman
Red Foreman's Avatar
Just checked out your thread on building your own column out of used GM stuff, I must say I was impressed!
Red Foreman is offline   Reply With Quote
