01-03-2012, 01:55 AM | #1 |
Fixing Reverse Lights... Gotta Check Everything!
Ok here's a good one.
The electrics on my truck are ok but there's a lot of little things that don't work on it so I've been attacking them one at a time. Today I went after the passenger side reverse light. Drivers side works fine. After about an hour of trouble shooting, I figured that the bulb wasn't grounding. Cleaned the bulb socket... nope that's not it. Cleaned the where the screws contact the housing.. nope that's not it. Took the housing out and cleaned the area of the housing that contacts the fender and the matching area on the fender... nope still no ground. More poking around with the MultiMeter and I figured out the problem. The socket must be crimped or swedged or pressed into the housing. For some reason there was no electrical contact between the housing and the socket. The fix: Since the housing and the socket couldn't be separated I cleaned up an area on both pieces, grabbed a scrap of 10 ga wire I had around, and soldered a "jumper" between the two pieces. |
01-03-2012, 10:42 AM | #2 |
Sisyphus was my mentor!
Re: Fixing Reverse Lights... Gotta Check Everything!
I had the exact same problem and I fixed it the same way. Damn near gave me an aneurism trying to figure it out...
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
01-03-2012, 11:35 AM | #3 |
Florida Edition
Good catch.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
01-03-2012, 03:45 PM | #4 |
Had the same problem but just soldered the socket to housing
Fuzzy |
01-03-2012, 07:55 PM | #5 |
01-03-2012, 07:56 PM | #6 |
thanks for the info. I am tackling this now.
01-03-2012, 08:27 PM | #7 |
01-03-2012, 08:30 PM | #8 |
when I removed the lenses to start my diagnosis I found the PO had not installed the bulbs. After further review I found that the wiring was not ther. I have ordered new cups, bulbs and a rear wiring harnees. After installing that I still need to find out if it works and if not, why.
01-03-2012, 08:37 PM | #9 | |
01-06-2012, 12:33 AM | #10 |
I'm new to this site, had the same problem, fixed it the same way just today. thanks it helped me,and save a few hours of chasin' wires.
01-06-2012, 12:40 AM | #11 |
Back-up Light? Are those supposed to work?
Did the 4spd trucks have this feature?
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
01-06-2012, 01:28 AM | #12 |
01-06-2012, 01:29 AM | #13 |
01-07-2012, 11:57 AM | #14 |
One day i wanted to see why my back up lights didn't work,found that the switch was gone.So call Classic Muscle in Winston Salem N.C. & they had a switch.Got home & put it in,then the fuse blown.Then i know i had a short in it some where & this is what i found.This is why you check everything.Hope this helps
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15. Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e, Last edited by RCbowtie69; 01-07-2012 at 12:03 PM. |
01-09-2012, 12:41 AM | #15 |
The switch for the grandma 4 spd, is on the trans.,driver side, on top. The trans operates it. Been awhile since I've been under there.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
01-16-2012, 04:16 PM | #16 |
have 72 chevy step side. been chasing wires and grounds. I put the blinker to the left works dim put license plate light blinks and the right marker likes blink.
turn on lights brake lights don't go on. its driving me crazy. I've checked fuses they look good replaced anyway. Any suggestions, thanks. Roberto |
01-16-2012, 06:50 PM | #17 | |
Pull the bulb out of the license plate light and see what happens. Do you have a multi meter to check the wiring? |
01-16-2012, 08:16 PM | #18 |
left signal turned, side markers go on leftside real strong and faint on right side.
pulled lic. bulb no difference. yes have a meter. |
01-16-2012, 09:13 PM | #19 |
It's gotta be a short or a ground. The left side should not be contact with the right side and neither should be in contact with the license light.
Trace it out using the meter set on ohms or a sounder if the meter has one. The circuit from the left side, the right side and the license should be separate and show open on the ohms. make sure you pull the fuses for the circuits you're working on. |
01-16-2012, 09:29 PM | #20 |
Here's a wiring diagram posted on another thread http://outintheshop.com/faq/wiring/wiring.htm
With it backing into the license plate light, I might want to disconnect it at the plug that's shown. |
01-16-2012, 09:46 PM | #21 |
My first guess would be a ground problem.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
01-16-2012, 09:52 PM | #22 |
ok you are right, ground or short.
i will check with meter, using ohms when open will meter register.(digital) I've checked grounds on engin to firewall. cleaned and reattached cab to frame. cleaned and reattached. I don't have one on box to frame. what do you think should I do that. I've checked for shorts physically. |
01-17-2012, 03:05 PM | #23 |
Make yourself a jumper from a length of wire and two alligator clips and attach one end to ground on the light and the other to a know good ground. if that fixes your problem then look at how the grounding between the bed and chassis.
01-17-2012, 11:28 PM | #24 |
just got home will try later thanks for your help.
01-18-2012, 01:50 PM | #25 |
I have the same problem (and know its a ground issue). I just haven't gotten around to fixing it. Heck, I have 2 reverse light. The second one is just a back up, right (no pun intended )
