5.3 Engine swap
Where do I find out how to install a 5.3 with automatic transmission from a 1999 1500 Silverado into my 1969 Chevy C-20. The 69 presently has a 307 4-speed all stock. Thanks for any help.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: 5.3 Engine swap
Look at the Lsx Swap thread, there is a FAQ there that will help you.
There really isnt much difference in swapping SBC's or LSX's except the motor mounts and the manifolds until you get to the wiring ( not a big deal either) You will need to shorten your drive shaft and do an electronic fuel pump. Also the trans will have a VSS for a electronic speedo, you can get a convertor for that tho.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Has more rust than truck...
Re: 5.3 Engine swap
Moving this to the LSx swap section. Check the FAQ link in my sig.
Re: 5.3 Engine swap
Thanks for info. Information I needed.
