01-03-2012, 09:01 AM | #1 |
69 Wrecker on SC CL
'69 short step with dreams of being a hot rod You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. |
01-03-2012, 10:17 AM | #2 |
Re: 69 Wrecker on SC CL
Wish i was closer, i'd love to have another one!
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
01-03-2012, 11:10 AM | #3 |
Looks like a good deal. I wonder if it's a C/20 with a 1t rear
01-03-2012, 11:14 AM | #4 |
Looks like the primered over the shop logos? Wonder if you could get the primer off without damaging the logos.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
01-03-2012, 11:17 AM | #5 |
Florida Edition
I'd say you could. I wouldn't mind having one to go with all my other stuff, I could do alot with two big winches.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
01-03-2012, 05:21 PM | #6 |
Well I would have looked MIGHTY hard at that one if it was up on CL two weeks ago. As it was I bought my 69 in Myrtle Beach. Columbia would have been a little shorter of a drive.
I really needed a proper truck box though so I would not have pulled the trigger on it. It is in much better hands with someone who will keep it as a tow truck. |
01-03-2012, 06:12 PM | #7 |
Couldn't we all my friend, couldn't we all.
01-03-2012, 06:35 PM | #8 |
Charlie Daniels w/ a Tq Wrench
It does appear that way with no cab lights and the SRW front end.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
01-03-2012, 07:20 PM | #9 |
A lot of guys will put 3/4 Ton Wheels on the Front End of their 1-Tons. They will fit fine and look pretty good too, although I personally don't like it that way. Also Cab Lights were not standard on a 1-Ton. Some will have them and some won't. The real way to tell would be by the VIN Number and/or the GVW rating.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
01-04-2012, 07:38 AM | #10 |
1969 Custom 30 wrecker
That sure does look like a good deal but the pics are small and not much description so who knows.
Nice to see one all together! I'm used to mine that is in pieces. That looks like it might even have a wreck master set up on it.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
01-04-2012, 07:48 AM | #11 |
That does look like a Wreckmaster. The rear looks like a later wider rear and from '69-on dual rear C/30s came with clearance lamps. The truck isn't bad.
01-04-2012, 09:21 AM | #12 |
Although I really like Clearance Lamps, I've got a '64, '65, '68 and a '72 all C-30's and all with no Factory Clearance Lamps (Cab Lamps), besides the many more I see on the road. ??? Bill
