01-03-2012, 12:47 PM | #1 |
Hydroboost heat up powersteering fluid?
Yesterday went to the salvage yard and pulled a hydroboost, pump,MC off of a 99 GM full size 2500 van. This will be going onto my 72. The van had a small oil cooler plumbed into the return circuit that was obviously factory. Is this a good idea to incorporate? I had never heard of cooling the powersteering fluid before.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
01-03-2012, 02:25 PM | #2 |
Re: Hydroboost heat up powersteering fluid?
Here is a picture.
01-03-2012, 09:27 PM | #3 |
The road race guys put them on regularly. I'd guess that since a loaded up van is heavy, that they run a lot of pump pressure to help people one finger the steering wheel in parking lots.
I'd probably leave it on. |
01-03-2012, 09:45 PM | #4 |
Has more rust than truck...
I'm running hydroboost with no cooler. I haven't road raced and if I drive hard its only for a short time. No problems......yet.
01-03-2012, 10:29 PM | #5 |
6>8 Plugless........
It's more for heavy towing. During hard braking/turning the power steering fluid can be heated up very rapidly and power steering fluid is burnt easily. The cooler isn't necessary for everyone, but if you plan to tow, I'd make sure to plumb it in your system.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-03-2012, 10:33 PM | #6 |
We install hydra boost systems all the time, brand new kits as well as piecing together stuff in drivers, never seen a problem not using a cooler. But it can`t hurt to use it as long as its in good shape.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
01-04-2012, 01:08 AM | #7 |
Old member
My dad had this and gave it to me a long time ago. Early 80's I guess, don't have any idea what it's for but I installed it on the 71.
01-04-2012, 09:05 PM | #8 |
Only thing this truck will ever pull is ladies. Hahahaha!! JK But I plan on using all 633 of those HP under the hood regularly so I went ahead and grabbed the cooler. Figured cool oil couldnt hurt much and the cooler plus extra hoses only weigh about 2 pounds. Looks like it will mount perfectly under the core support just like it did on the van
01-04-2012, 10:37 PM | #9 |
Most all of the later model GM trucks [going back to 1988] had a power steering oil cooler. Hydroboost is not a factor in it most trucks have or had the cooler. I have had several hundred of those trucks come thru my shop one way or another, and I have seen a lot of them. In fact, I thought about this post today when I was at the shop and saw about 6 of them laying outside the shop by the door.
01-04-2012, 11:09 PM | #10 |
I put the factory cooler that came with the hydroboost on my truck, just 'because', guess you can't really over cool it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
01-04-2012, 11:29 PM | #11 |
i've never run hydroboost so i can't help there but heres a picture of the powersteering cooler on my truck i guess they didn't start putting fins on for a while this one came on a 76'
i know its not really needed but i figured the same thing why not run it and i've never felt it get hot so i guess its working |
