01-03-2012, 01:07 PM | #1 |
house of chevy's
shock ?
I posted in the suspension section no one seems to want to answer so ill try here im in the process of rebuilding my front end my ? Is my truck is lowered 4 in front the shocks apear to be stock size is that correct or do i have to run a drop shock tryin to have all my new parts ready to be installer at same time any help would be great
1987 m1028 cucv d30 2001 chevy s10 2000 honda shadow sabre 1100 "it's going to be an interesting ride home" |
01-03-2012, 01:15 PM | #2 |
Re: shock ?
I'm not an expert with suspension but I'd be afraid of bottoming out my stock shocks a lot with a four inch drop. Lets let someone who knows about it chime in though.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
01-03-2012, 05:42 PM | #3 |
Spear and magic helmet!
Re: shock ?
Depends on how it's lowered. If it's lowered by spindles then the suspension travel hasn't changed as much so new shocks may not be needed. For example, if you have a 3" drop spindle and 1" drop spring, you're probably OK on stock shocks. If you just have 4" drop springs, you're definitely going to need new shocks.
01-03-2012, 09:53 PM | #4 |
house of chevy's
Re: shock ?
I bought my truck already lowered so in not compleatly sure how its lowrted but the shocks qpear to be stock size
01-03-2012, 10:35 PM | #5 |
Re: shock ?
Do you have any pics of your front suspension? With a 4in drop I would bet you have drop spindles. If so stock shocks are OK. IF you dont have a pic you can compare your spindles to these. The one on the left is stock, the one on the right is a 2.5 drop spindle.
John 82 Chevy Silverado 350ci/TH350 |
01-04-2012, 10:21 AM | #6 |
house of chevy's
Re: shock ?
From ur pics looks like i still have stock spindels
01-04-2012, 11:02 AM | #7 |
Re: shock ?
If you still have stock spindles I would recommend getting drop spindles and lowering springs or stock springs and cutting one round off to get the 4 in drop. Going more than 3in with springs only you will run out of alignment bolt and quickly wear out your front tires. Also every time you lift the front of the truck to work on it the springs will fall out of place. If you make these changes you can run stock shocks.
01-04-2012, 11:18 AM | #8 |
house of chevy's
Re: shock ?
Ive been drivin around for two years with the truck lowered that way havnt had any major problems my front yires are just now showin some funny wear had the front end off ground quit a few times never had the spring even close to fallin out
01-04-2012, 11:33 AM | #9 |
house of chevy's
Re: shock ?
I took off a skock and on it it says gabriel gas ryder is this a stock replacment shock or is it a drop shock
01-04-2012, 11:40 AM | #10 |
Re: shock ?
i notice that you said you bought your truck already lowered. how are you determining it is a 4" drop, is this something the previous owner told you or have you made some measurements of some sort to determine this. my guess would be he cut a round of coil off the stock springs, and due to the age of the springs, it has lowered the front more than the traditional 2".
01-04-2012, 11:43 AM | #11 |
house of chevy's
Re: shock ?
Going by what the po told me the springs dont look like there cut but im not 100% there not
01-04-2012, 11:48 AM | #12 |
Re: shock ?
Do you have any pics of the truck you can post?
01-04-2012, 11:49 AM | #13 |
house of chevy's
Re: shock ?
Click on my name at left theres some there
01-04-2012, 11:53 AM | #14 |
Re: shock ?
Looks like a 3-4 in drop to me. If it was mine I would put stock shocks on it, with no worries.
John 82 Chevy Silverado 350ci/TH350 Last edited by J Knight; 01-04-2012 at 12:00 PM. |
01-04-2012, 12:03 PM | #15 |
house of chevy's
Re: shock ?
I dont know its got a flip kit in rear with a leaf taken out i have a bunch more pics on phone but cant seam to figure out how to post em all i know is its low my exhaust constantly hits ground
01-04-2012, 12:25 PM | #16 |
Re: shock ?
unbolt ur shock from the top, compress it all the way while keeping it on the same axis it normally rides at, measure the distance from the mount to the shock. This is the length of ur avaliable travel on the shock.
Now measure the distance from bumpstop to its contact point, now guestimate how much it will compress. Does ur shock have enough stroke? If not its too long. Now yes some angles and other variables come into play so have to use ur judgement on that. Now that is not a for certain way, but a very easy way. If ur measurments are real close, they its best to go ahead and get shorter shocks. If u have an inch or two of extra shock travel then ride it. Or just make the suspension flex enough to see what it will do in real life. |
01-04-2012, 06:09 PM | #17 | |
house of chevy's
Re: shock ?
01-04-2012, 09:35 PM | #18 | |
Re: shock ?
Look up the p/n of the shocks you have & see what they're supposed to fit.
01-04-2012, 10:03 PM | #19 |
house of chevy's
Re: shock ?
There so rustdd i dought i could still read it it just so happend wear the sticker was against the frame so i could still read what theh were
