Old 01-03-2012, 03:50 PM   #1
TJBrown
TJBrown's Avatar
Testing a Jumping Speedometer
Forgot to post this but i was having an issue with a speedo jumping on me at low speeds. I decided to do process of elim and figured out this little trick to bench test the speedo. I got a Q-Tip and put on end into a drill and put the other end of the Q-Tip in the back of the SpeedO housing. You can pull the trigger on the drill and test low mph all the way up to 75 mph (as fast as my 9.6v dewalt would turn) as a bench test. SpeedO was good, Turned out to be the upper cable. Hope this might help someone in the future.
85 Silverado SWB
TJBrown is offline   Reply With Quote
Old 12-15-2012, 02:27 PM   #2
C-10 simplex
Re: Testing a Jumping Speedometer
Thank you.
C-10 simplex is offline   Reply With Quote
Old 12-15-2012, 03:48 PM   #3
GM-power
GM-power's Avatar
Shot grease in my cable line and once it got lubed up no more waving.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 12-15-2012, 07:12 PM   #4
cmyc5575
I think that this is the issue with mine. You can hear it grinding likes its right behind the cluster.
cmyc5575 is offline   Reply With Quote
Old 12-16-2012, 10:55 PM   #5
gmclowsierra
Unhook.the cable from the speedo head and put a light oil down thr cable. Should loosen cable and smooth out the jumping needle.
gmclowsierra is offline   Reply With Quote
Old 12-17-2012, 12:09 PM   #6
JRANGER
JRANGER's Avatar
I had that problem too...but mine turned out to be multiple speedos...I finally got one that works after replacing the speedo cable, greasing the new cable, and buying several clusters from pull a part lol
JRANGER is offline   Reply With Quote
