Old 01-03-2012, 08:26 PM   #1
mobileortho
mobileortho's Avatar
Caddy tail lights
I really like the looks of the 89-93 Caddy Deville and have considered mounting them in the rear stake pockets on my AD. I've only seen photos of them and I'm not sure if they'll fit. The length & width look fine but does anyone know how deep they are?
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 01-05-2012, 01:08 AM   #2
sirwilliam
Re: Caddy tail lights
Im pretty sure they are too deep, at least an inch...
sirwilliam is offline   Reply With Quote
Old 01-05-2012, 01:58 AM   #3
55metalmonkey
you mean like this type kit? I looked into it for my 55 GMC (TF) I'm not sure on dimensions for a AD but the measurements required are on the link. there are LED kits that don't need as much space.
http://modshopinc.net/store/index.ph...roducts_id=535
Hope this helps.
55metalmonkey is offline   Reply With Quote
Old 01-05-2012, 04:48 AM   #4
Daze57
Daze57's Avatar
just got a pair from the yard off a 93 deville - measures - from side edge of bezel to back of lamp housing ( lamp in place and connector on ) measures 4 1/2 inches deep @ its widest. Hope this helps.
Daze57 is offline   Reply With Quote
Old 01-05-2012, 10:20 AM   #5
mr48chev
mr48chev's Avatar
They look ok in some fleetsides but I'd have to think that they would look just wrong on the back of an AD truck. Quite similar to all the Mustang tail lights that people stuck on the backs of trucks in the late 60's and early 70's.
It isn't always about change for the sake of change but every change should flow and blend in with the whole truck so that it's part of the truck and not something that appears stuck on or added just because the cool guys are doing it.
Old 01-05-2012, 12:46 PM   #6
Daze57
Daze57's Avatar
i think we are all cool guys
Old 01-05-2012, 02:50 PM   #7
poncho_villa
poncho_villa's Avatar
It's true! I read that in the brochure.
58 Apache short fleetside ona 64 chassis:
poncho_villa is offline   Reply With Quote
Old 01-05-2012, 05:19 PM   #8
oldman3
oldman3's Avatar
I'm not sure how that would look on the 47-53 bed stake pocket it has a different shape. But here are a few pics of ones I installed. The first are 3rd brake lights rebulbed to work as running and brake lights on my AD with a 54 bed (different stake pockets). The second group is the caddy light (these are the LED type and are made to fit were depth is a problem). They were installed on a 67 step side bed in the stake pocket. Hope this helps......Jim
oldman3 is offline   Reply With Quote
Old 01-05-2012, 05:33 PM   #9
mobileortho
Well at 4.5", that would be too wide for the AD. Thanks for the info!
Robert C.
1950 3600
Old 01-05-2012, 05:33 PM   #10
mobileortho
Great looking trucks!
Robert C.
1950 3600
Old 01-05-2012, 07:34 PM   #11
mknittle
mknittle's Avatar
That looks good.Aren't the 54 up stake pockets curved?
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 01-05-2012, 09:32 PM   #12
Daze57
Daze57's Avatar
mobileortho
i meant 4.5 deep - from front to back. not looking straight on at it wide -
i hope that makes sense .good luck
My 97 deville lites work well when tested - i think they are good lookin and different .
Old 01-06-2012, 12:21 AM   #13
mobileortho
mobileortho
Yep. I got cha. The AD's stake pocket is only about 2" deep, so without some signigicant mods thy wouldn't work.
Robert C.
1950 3600
Old 01-06-2012, 12:27 AM   #14
Daze57
Daze57's Avatar
Rats ! well i hope ya find some good lites - watsons street works carries really nice L E D lites also maybe sumthin there will work for ya
'' nuttin like the blue ridge mts. of virginia '' -ask laurel and hardy !
good luck
Old 01-06-2012, 11:34 AM   #15
booger1949
why not make them two stake pokets a little wider to handle the cas lights
booger1949 is offline   Reply With Quote
Old 01-07-2012, 05:00 PM   #16
_Ogre
_Ogre's Avatar
these are $7 led lites from jcwhitney that i installed on the back of my 58.
you could stack them in your stake pocket, 3 high. 2 stop and 1 tail lite.
they are 7/8'' wide, 3/4'' deep and 4.5'' long.
in my truck
Old 01-09-2012, 12:57 PM   #17
Daze57
Daze57's Avatar
your tailight set up looks really very nice - whole truck is great looking !
