Old 01-03-2012, 10:13 PM   #1
hairlesshobo
hairlesshobo's Avatar
dumb question, and an easy one at that
I keep seeing people mention it, but I cant figure out what it is. In this case, google wasn't even helpful...
What does it mean to Z a chassis??
Thanks in advance
-Steve
Shawty: '84 C10 Silverado SWB, 700r4, SBC 350 - 4 bolt main, bored 60 over w/ Weiand aluminum intake and moderate cam, 2" true dual exhaust, Thrush mufflers, 3.42:1 gears -- Build Thread
The Tranny (wrecked ): '86 Trans Am, SBC 350 (now in above truck), Borg-Warner T-5, 2" true dual, Thrush mufflers, 2.73:1 gears
hairlesshobo is offline   Reply With Quote
Old 01-03-2012, 11:39 PM   #2
dv8customs
dv8customs's Avatar
Re: dumb question, and an easy one at that
It is done to allow the vehicle to be lower or provide more clearance. Cut the frame just forward of the firewall and raise it up the desired amount. Add bracing and weld it all back up. Then repeat the process by the same amount on the front frame horns. This moves the control arms up relative to the bottom of the frame.
dv8customs is offline   Reply With Quote
Old 01-04-2012, 04:31 PM   #3
hairlesshobo
Now I understand. Now I will know a little better what I'm looking at when I'm looking at the awesome chassis pics that I see on this forum.
Thanks!
-Steve
Old 01-04-2012, 05:12 PM   #4
csa daddy
csa daddy's Avatar
Z ing is a old school low cost drop where alot of people now instead of cutting up there frames are running porterbuilt crossmembers instead of z ing
csa daddy is offline   Reply With Quote
Old 01-04-2012, 07:01 PM   #5
jimmydean
jimmydean's Avatar
Much safer alternatives, but if done right is still effective.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
