side molding adhesive ?'s
so I finally located and bought some very good almost perfect upper side molding for my 72 LB. What do you all suggest for adhesive for the plastic clips that go on the side of the truck. I was thinking some of the 3m double sided adhesive pads. Any and all suggestions please.
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
Man of Mini-Talents
Re: side molding adhesive ?'s
3M is what you want. Just make sure it's automotive quality.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#3 | |
The Older Generation
Yep, that would be with the red peel off backing. That's what I used on my '71. LockDoc
3m with red back, thanks.... any local auto store I take it
VA72C10
![]() Join Date: Mar 2008
I get it at walmart as it's cheaper...just make sure to get the auto grade not the craft stuff as it's not as strong (get it from the auto dept where the touch up paint is usually)
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
I got mine at NAPA. I'm 20 miles from the nearest Wally-World...Shop local!.. ![]() LockDoc
Local for sure !
VA72C10
I guess I should note that I literally have two walmarts within 3 miles of my house..the one I go to most is within 1 mile (about 3 minutes away if I catch the lights just right).......and six walmarts within 25 minutes of my house...
we have 3 wal marts seperate towns but all 10 min away
so screw are not how suppose to be used to hold the top trim to the body?
just like that old Johnny Cash song. "One piece at a time and I am go na make an old C10 mine a look at all your faces when I drive through your town" |
#13 | ||
- Front fender & cab corner moldings use metal clips with studs that are secured with nuts on the back side. - Door moldings have a screw at the front and a stud-clip w/nut at the rear edge. The remaining clips in the middle are either springy metal type clips that snap into holes or the adhesive backed plastic clips. I believe GM used the snap-in clips for 69-70 and the adhesive ones for 71-72. - Bedside moldings have a metal snap-in clip at each end for all years. The remaining clips in the middle are either more snap-in clips (69-70) or the adhesive backed clips (71-72). The adhesive backed clips could be used in more locations than they were from the factory to reduce the number of holes. Especially on the front fenders. Quote:
