Wheel and tire help
So I have these wheels laying around in my garage. I know nothing when it comes to back spacing or anything like that. My 70 is a 6 lug truck 2wd. These wheels I purchased for my 2011 silverado will they work on my 72?
http://www.tirerack.com/wheels/Wheel...All&sort=Brand Posted via Mobile Device Specs Front and Rear Size: 20x8.5 Offset: +35mm Backspacing: 156" Bolt Pattern: 6-139 Rec. Tire Size: 275/55-20 Weight: 33.0lbs. Finish: Chrome Plated Construction: 1 Pc.
1970 c10 2wd th400 and a stock 350...BBC soon to follow ~ Mild Built 454 Sitting in my Garage 2011 Silverado Crew Cab 6.2L Fast Motorsports Performance Tune 20 inch KMCs Nitto Terra Grapplers BDS Leveling Kit Last edited by Chrislidgett; 01-04-2012 at 12:57 AM. Reason: Added wheel specs |
![]() Join Date: Oct 2009
Re: Wheel and tire help
don't quote me (which I realize renders this input useless...) but I believe the hub diameter is different between the "newer" 6 lug half ton trucks and the "older" 3/4 ton trucks (i.e. the bolt circle is not the issue, it's the hub center opening diameter....) I do know this is the case when comparing 60-66 C10 6 lug wheels and newer 90's ish and up C10 6 lugs - but am only ASSuming this is the same problem for 67-72. So, I'm looking to learn something here as well....
Bueller? Bueller? |
yep the center bore will be too small
My 70 is a 1/2 ton btw....so what I gather is the center cap opening is too small?
1970 c10 2wd th400 and a stock 350...BBC soon to follow ~ Mild Built 454 Sitting in my Garage 2011 Silverado Crew Cab 6.2L Fast Motorsports Performance Tune 20 inch KMCs Nitto Terra Grapplers BDS Leveling Kit |
