Old 01-04-2012, 02:18 PM   #1
mongoose
mongoose's Avatar
suspension gurus - sway bars..
Thinking of running a splined swat bar/torsion bar in the front of my truck. One problem though, there's a million different rates.. Which one would be good to run? Starting point? Wanting something a bit stiffer than what a hotckis bar would be.. As I'm running not the stiffest spring in the world.. Any ideas?
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 01-05-2012, 08:52 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: suspension gurus - sway bars..
You might try sending a PM to member/vendor robnolimit.
Keith
Convert to disc brakes.
Old 01-05-2012, 11:11 AM   #3
cajundragger
I called speedway engineering and had those guys set me up with a bar that has many rates above and below it in the same size.
cajundragger is offline   Reply With Quote
Old 01-05-2012, 12:32 PM   #4
robnolimit
robnolimit's Avatar
Try using a 1 1/4" dia. x 48 spline bar. Start with a .188 wall. once you have the mounts and arms fitted, swapping to a stiffer, or softer bar is easier. I use these a lot, but there isn't much room in the parts $$ wise. Go direct to Speedway Engineering, or www.1speedway.com they can help you out. - you can use normal, street friendly urathane to mount the bar.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 01-06-2012, 04:56 AM   #5
andrewmp6
That is why I'm happy rob is here he knows his stuff well and more then helpful on anything.
andrewmp6 is offline   Reply With Quote
