Air cleaner mounting
Was looking at my carb today and am wondering if something is broken off or just missing? I don't see a threaded hole for a missing post. Is there a part that I need to mount the stock air cleaner body? Thanx!
Re: Air cleaner mounting
yes there is a part missing..... it is a flat bar that goes in the top of the carb. It slides under the notches you can see in the top of the carb. the bar is helds in by two small roll pins. the bar actually looks like a small piece of channel iron
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide Last edited by sigshooter; 01-04-2012 at 08:55 PM. Reason: grammar |
Thanx! any chance someone sells replacements? Guess I could just go with a chrome clamp on type if not.
What the determining factor is if the ears on the top of the carb that hold the flat bar are still there. They commonly break off. Ill see if I have any spares laying around. Try and get a pic of the top of the carb for me. Here is a pic...look right behind the choke flap and you can see the mounting bracket.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 01-05-2012 at 09:44 AM. |
