Old 01-04-2012, 11:17 PM   #1
Clownpuncher
Clownpuncher's Avatar
Man I need some Column help..
(Auto Column shift)
Okay so I put in a new turn signal switch and a few other things. Right now I'm trying to get my shifter to release the mechanism ( The Gate on the outside of the firewall) correctly. For some reason when I put my shift lever it pulls the slide housing fine but doesnt not release it enough.
So was the ball on the end of the shifter handle suppose to pivot on the main steering column shaft? I've looked at blow up's and it seams I didn't loose anything. Please help
This is a crappy picture of shifter coming through the column to the shaft if I mount with out the dowel pin
And here it is when I mount the shift level completely. Notice the ball does not come through and touch the shaft. If this is the way it's supposed to be it seams I have hardly any tension on the shift lever
Chuck
Clownpuncher is offline   Reply With Quote
Old 01-05-2012, 01:48 AM   #2
1964c-10
1964c-10's Avatar
Re: Man I need some Column help..
make sure the main steering shaft is centered when testing, you may have to remount the steering wheel to ensure this.
2003 Serria K1500
1998 Camaro
1964 C10 long fleetside bed, small back window, 3 on the tree
1964 C20 custom cab, long fleetside bed, big back window, 4 on the floor
Disclaimer- anything posted is only based on my personal experience, opinions, and advice given by others. There are no implied or written warranties or guarantees with anything posted on this website.
1964c-10 is offline   Reply With Quote
Old 01-05-2012, 02:29 AM   #3
Clownpuncher
I was thinking the same thing before hand I thoguht I had it centered enough well I said screw it and bolted it ll back up and once the turnsignal was put back on it really tightened it up. Now I have adequate through.
Old 01-05-2012, 02:43 AM   #4
1964c-10
1964c-10's Avatar
i was having problems with my 3 on the tree and i had to grease and reassemble it several times to get it sliding good
2003 Serria K1500
1998 Camaro
