01-05-2012, 11:23 AM | #1 |
Nuts and bolts
It's time for me to get the needed fasteners to put my truck back together.
I want to use SS for most everything. Does anyone know where I can get flanged SS bolts from. I don't want to buy a kit there over priced and I would like to pick the bolts I need. Thanks for the help |
01-05-2012, 12:05 PM | #2 |
Re: Nuts and bolts
I got most of my SS bolts from Lowes in the specialty section/hardware
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
01-05-2012, 05:14 PM | #3 |
Re: Nuts and bolts
292 + TKO500 |
01-05-2012, 07:18 PM | #4 |
Re: Nuts and bolts
I will give you a warning about stainless bolts. You have to be careful with some bolts coming from overseas nowadays. One thing you want know is if using a stainless bolt and stainless nut: sometimes they can seize together and twist-off. Im talking new stuff. I had a 1/2" nut seize on a bolt and i had to cut it off. Always use a "never-seize" product. I use the permatex brand. Some stainless bolts are hard to drill. I reccomend only using them in areas that are seen.
01-05-2012, 07:20 PM | #5 |
Re: Nuts and bolts
my Ace has a good selection. Check 'em out if you have one near by.
01-05-2012, 07:26 PM | #6 |
Re: Nuts and bolts
Hey farmer, I get most of my bolts from Parkrose Hardware which is an Ace Hardware affiliate. They have a huge selection of stainless. I really haven't looked for flange bolts but if they don't have them they can probably get them for you. They also have a selection of polished and chrome behind the counter if you ask.
01-05-2012, 08:58 PM | #7 | |
Re: Nuts and bolts
01-05-2012, 09:01 PM | #8 | |
Re: Nuts and bolts
Thanks |
01-05-2012, 09:08 PM | #9 | |
Re: Nuts and bolts
Next week the body comes home from the paint shop will be posting pictures. Thanks |
01-05-2012, 09:37 PM | #10 |
Re: Nuts and bolts
It is my experience that stainless bolts are not nearly as strong as graded automotive bolts, keep that in mind. Should be OK for putting a bed together.
If you are looking for bolts for bed strips, search for carriage bolts. All the soureces listed so far are good. |
01-06-2012, 01:15 AM | #11 |
60-66 Nut
Re: Nuts and bolts
I haven't bought stainless flange bolts, but I have bought plated steel flange bolts from Fastenal. You have to buy in package quantity from Fastenal, and they are on the pricey side in my experience.
