Old 01-05-2012, 11:36 AM   #1
billybobjimmyjoejack
Wipers are slow, then stop.
I have a 79' GMC with the standard two speed wiper switch. After the wipers have been running for a while they will start to slow down then eventually stop. If I leave the switch "ON" they eventually start back up. If I turn the switch "OFF" and "ON" a few times eventually they come back on. When the wipers come back on they work fine for sometime and other times they don't.
billybobjimmyjoejack is offline   Reply With Quote
Old 01-05-2012, 08:30 PM   #2
77chevyinline6
77chevyinline6's Avatar
Re: Wipers are slow, then stop.
check the switch and wiring and defianatly your wiper motor its prob that
77 c10 (went from a inline 6 to 350) (converted to 3 speed in the floor)
350: mild cam, holley 600cfm 4bbl, summit stage 1 intake, accel billet distributer, flowtech headers, 2 1/4" exhaust with glasspacks, powermaster 160a alternator.
77chevyinline6 is offline   Reply With Quote
Old 01-05-2012, 09:44 PM   #3
sethv
sethv's Avatar
Check your fuse, mine was having similar issues and I took the fuse out and cleaned the contacts, and it solved it.
1981 K10 Scottsdale
305 ci | TH350 | NP208 |
60k miles
sethv is offline   Reply With Quote
Old 01-06-2012, 12:52 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
My 78 jimmy switch pushed out the back
Was ez to fix , the switch posted in thread below
Sometimes the copper ground strip is bad/green
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 01-06-2012, 01:21 AM   #5
cory d
cory d's Avatar
a while ago i was driving at night and my lights dimmed and my wipers slowed down to a snails pace. it ended up being a connection to my alternator, it was loose adn dirty. i cleaned it up a little and plugged it back in and it fixed the problem.
cory d is offline   Reply With Quote
Old 01-06-2012, 11:49 AM   #6
patrickth
The first thing I always check in this situation is the ground wire. 9 times out of 10, its going to be the issue with the symptoms you describe.
patrickth is offline   Reply With Quote
