trailing arms vs. a parallel 4 link...
this is for my '49 chevy 1/2 ton on a s10 frame, static drop (no bags).
i'm playing with the idea of using a trailing arm set-up from later model trucks (i've got one laying around) my question is if i were to use coil overs would there be an advantage/disadvantage to a trailing arm set-up vs. a parallel 4 link? my goal is a daily driver (healthy 350/700r4 combo) that handles great and i can drive the snot out of ![]() thanks.
"When in Rome we shall do as the Romans,...when in Hell we do shots at the bar." |
Re: trailing arms vs. a parallel 4 link...
with the trailing arms you are going to get some pinion angle change when the suspension is cycled. with a parallel 4 link, when setup right, you are not going to have any pinion angle change. when you set it up with the trailing arm you might have to shim the rear or relocate the axle brackets. the suspension gurus will jump in hopefully and talk about anti squat, roll center, live center and all the tech. stuff. lol. good luck with the project.
Hollister Road Co.
The pinion angle does change on a truck arm setup but the joint does not change much relative to the shaft angle which is what your concerned about. I have a 72 that I load up heavy, its squats about 4 inches down in the back and I have no issues with vibration and pinion angles.
On parallel bars the joint angle changes a lot more. But remember your not moving the suspension much more that a inch in either direction while driving. So it shouldn't be an issue with either one. Truck arms ride much better in my opinion. trailing arms, truck arms are the same thing. Its what NASCAR uses for rear suspension |
#4 | |
#5 | |
like so:
#6 | |
i'm gonna start doing some measuring tonight and move forward with the trailing arm set up. i've heard nothing but good about the ride and (with the right springs/shocks) the handling. i also have to admit i've done alot of reading here from robnolimit http://67-72chevytrucks.com/vboard/s...d.php?t=419251 which inspired me to,...well, "make it handle".
