Cab Mounting Spacer?
Does anyone know the size of the bolt spacers used on the standard Cab and Radiator mount bushings? Come to find out the bolt and bushing kit I bought didn’t come with them and LMC wants $61 for all 6… I was hoping I could just pick some up from the hardware store. I have a 70 C10 2wd.. Thanks
Re: Cab Mounting Spacer?
I make my own out of pipe and make the pipe to length depending on whether the mounts are rubber of plastic. On the rubber mounts you will need a little "crush" on the rubber so the pipes are made 1/4" to 3/8" shorter then the stackup.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Thanks for the info, I kinda figured they would have to be a little shorter than the rubber but what type of pipe do you use?
