Old 01-05-2012, 06:55 PM   #1
zicc1835
zicc1835's Avatar
WTB 2 barrel carb 2 jet rochester /with manuel choke
[FONT="Arial B
zicc1835 is offline   Reply With Quote
Old 01-05-2012, 09:51 PM   #2
jaros44sr
jaros44sr's Avatar
Re: WTB 2 barrel carb 2 jet rochester /with manuel choke
got one, but i dont think it has a manual choke...ill check tomorrow
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-05-2012, 10:55 PM   #3
zicc1835
zicc1835's Avatar
thanks
Old 01-06-2012, 01:27 PM   #4
jaros44sr
jaros44sr's Avatar
it is an electric choke, but should be able to convert, dunno
actually, just looked at it again, and it is a hot air choke, front fuel inlet
do you a pic of the choke side of the carb
SAFETY FIRST
AS usual, off topic
Jim
Old 01-06-2012, 04:50 PM   #5
paul mora
I have a nice monojet i will sell for 40.00 shipped
Pulatoy
paul mora is offline   Reply With Quote
Old 01-06-2012, 05:51 PM   #6
67gmcstepside
i have one and will check for man choke as well
67gmcstepside is offline   Reply With Quote
Old 01-06-2012, 07:34 PM   #7
zicc1835
zicc1835's Avatar
im sorry do you want a pic or are you asking me if i want a pic of the choke side and what will you want for it if it works for me
thanks Jess
Old 01-06-2012, 07:37 PM   #8
zicc1835
zicc1835's Avatar
can you send pics of monojet is this a ready to run or will need to rebuild
thanks
jess
Old 01-06-2012, 07:37 PM   #9
zicc1835
zicc1835's Avatar
thanks very much
Old 01-06-2012, 07:43 PM   #10
paul mora
Pulatoy
Old 01-06-2012, 07:45 PM   #11
paul mora
http://67-72chevytrucks.com/vboard/a...1&d=1299878406
Not sure if that worked it was on a old thread I had for for sale and it was and is 35.00 shipped and worked fine when I took it out of the truck
Pulatoy
Old 01-06-2012, 09:03 PM   #12
jaros44sr
jaros44sr's Avatar
thanks Jess
i dont want anything for it, if you can use it. i just thought i could help if you could show me a pic. of the carb on the choke side
SAFETY FIRST
AS usual, off topic
Jim
Old 01-07-2012, 12:15 AM   #13
zicc1835
zicc1835's Avatar
it was i who was confused sorry .... here are 2 pics side view shows where the cable attaches on what would be the drivers side just above the the accelerator linkage ....i will take a close up tomorrow if need be thanks for your help with this
Jess
Old 01-07-2012, 12:25 AM   #14
zicc1835
zicc1835's Avatar
that worked.... it looks like the base is much different then mine i have 4 hole for studs looks like this has 2 one on each side like a 1 barrel ? unless im wrong i don't think that one will fit if its not to much trouble a picture of the base will help thanks
Jess
Old 01-07-2012, 10:27 AM   #15
zicc1835
zicc1835's Avatar
ttt
Jess
Old 01-07-2012, 02:02 PM   #16
jaros44sr
jaros44sr's Avatar
the only thing that bothers me is that mine has a front fuel inlet. you should be able to switch your manual cable over to mine
does your manifold have the mounting boss for a divorced choke?
SAFETY FIRST
AS usual, off topic
Jim
Old 01-08-2012, 01:11 AM   #17
zicc1835
zicc1835's Avatar
if you mean where the heat activated choke hooks to then yes
Old 01-08-2012, 09:59 AM   #18
jaros44sr
jaros44sr's Avatar
ok, then this carb would work as is, if you want....
do you want it?
SAFETY FIRST
AS usual, off topic
Jim
Old 01-08-2012, 11:14 AM   #19
zicc1835
zicc1835's Avatar
yes pm sent
do you want it?
Old 01-08-2012, 01:39 PM   #20
jaros44sr
jaros44sr's Avatar
yes pm sent
didnt get it
SAFETY FIRST
AS usual, off topic
Jim
Old 01-08-2012, 10:02 PM   #21
zicc1835
zicc1835's Avatar
Just saw this now resent. Pm
didnt get it
