Old 01-05-2012, 07:28 PM   #1
cfan10
cfan10's Avatar
Cool Swap engines, how to advice, please
I'm wanting to do a swap of my 305 v8 to vortec 5.7, what will I need from donor vehicle besides engine wiring harness, ac compressor.
Will 5.7 bolt up to tranny. I just want better mpg and hp. They also seem to be mostly troublefree. Friend's mechanic will most likey do the job, as he swapped her engine out in a few hours. Mine should be a week, maybe?
Anyone did the swap before advice/troubleshooting possibly pics. Any help will be great, and sincerely appreciated.
Current specs:
84 shortwide
305 v8
Edelbrock 4 barrel carb
True dual exhaust
Auto trans/not sure which one though
Can engine come from any 90's and up 5.7 gm vehicle? Thanks, again.
cfan10 is offline   Reply With Quote
Old 01-05-2012, 09:00 PM   #2
sean1969c10
sean1969c10's Avatar
Re: Swap engines, how to advice, please
The 5.7 Chevy will bolt right up to the 305's transmission. If you have a donor vehicle you may want to use the overdrive trans that will likely be behind the 5.7 Vortec engine.
Sean
"If your gonna be dumb, you gotta be tough"
1960 Chevy Impala Sedan - my 25 year search is over!!
1969 C-10 longbed - Nice day DD
1970 Chevy Nova - Street and Strip Project
2002 Acura MDX my DD
2007 Honda Odssey - My Wife's "Mommy Van"
sean1969c10 is offline   Reply With Quote
Old 01-05-2012, 09:09 PM   #3
cfan10
cfan10's Avatar
Thanks man, but no donor just going to browse salvage yards/craigslist.
Old 01-05-2012, 09:13 PM   #4
sean1969c10
Were you planning on running your carb or going injected?
Sean
Old 01-05-2012, 09:42 PM   #5
Low84
Low84's Avatar
I think the vortec 350's didn't come out till '96.
Low84 is offline   Reply With Quote
Old 01-05-2012, 09:52 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
That is correct. The 5.7 prior was a TBI that was a DOG.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-05-2012, 11:14 PM   #7
cfan10
cfan10's Avatar
Cool Re: Swap engines, how to advice, please
Injected. I have a 98 burb with 5.7l and I've fallen in love with it, after getting it back from little bro.
Can distributor or alternator be reused from 305 on 5.7?
Old 01-06-2012, 01:34 AM   #8
C15_Sierra
C15_Sierra's Avatar
Your best bet to extract the most mileage would be the 5.7/4L60E (OD tranny) from a donor vehicle, as stated above. I was in the same boat and I ultimately went with a 5.3/4L60E swap in my truck in place of its 305/TH350. That said, my research indicated that there were gonna be similar obstacles to Vortec 350 swap as the 5.3 swap, mainly wiring, fuel system, and AC system. Of course, though, you'd be able to keep your stock exhaust, motor mounts, etc.
I don't know about the computer for the Vortec 350, but the 5.3 was designed to use the 4L60E, so it has tranny controls built in, and you'll be able to plug n play. If you have a 700R4 (mechanical version of a 4L60E) you'll be able to swap and still keep your driveshaft and tranny cooler. I'm not sure if the Vortec 350's have provisions for a TV cable which the 700R4 has because they were designed to use 4L60E's, which eliminated the TV cable.
Next, your fuel system will need an upgrade, because you're running a carb right now. Some LS folks swap tanks to the '87 tank which has an in-tank pump (you'll need to change the pump to a higher flow pump) and a baffle to keep fuel near the pickup. Some others run the carb tank and run an external pump, but you wouldnt be able to drive with less than a 1/4 tank or so before you start starving the pump. You'll also need new lines to deal with the increased pressure. IIRC, Vortec 350's use about 45 or so PSI of pressure in the lines.
AC compressors are different because they use R134a instead of the old-school R-12, so on top of the engine swap, you'll have to retrofit your old system (if it hasn't been done already). That is, if you wanna go that route.
Like I said, many of the above issues are the same as going the LS route, and given that Vortec 350/4L60E combos were going for the same rate as a 5.3/4L60E, I naturally chose the option that gave me the best mileage and power combo. Not to mention, there are simple bolt-ons that will raise the performance level of the stock 5.3.
Hope I didn't scare/overwhelm you...best of luck, and keep us updated!
-Steve
1980 GMC C15 Sierra LWB
Dark Carmine Red/Carmine Int
Was: 250/3spd (1980-88), then a 305/TH350 (1988-2011)
Now: 5.3/4L60E, 2.73 12-bolt open rear
C15_Sierra is offline   Reply With Quote
Old 01-06-2012, 10:05 AM   #9
sean1969c10
If you really want to do this my advise is to find a donor truck, there too many little things you'll need to make the swap that will be a pain to have to run to the Boneyard all the time. You'll also know that the engine runs and the trans works before the swap as long as you get a running donor. No the distributor won't interchange and if you use the serpentine system from a Vortec engine the alt won't work either. This swap will more than likely take more than a week to do. Good luck, it will be a nice swap!
Sean
