01-05-2012, 08:46 PM | #1 |
wiper problem
hey there guys just bough a 72 cheyenne super and the wipers dont seem to be working right lol they wont shut off in the right spot (in the down postion ) they stay pointing up does any one no if thats in the motor or is it some other problem i have changed the switch and made sure the ground is all good
01-05-2012, 08:53 PM | #2 |
The Older Generation
Re: wiper problem
Do they wipe across the windshield correctly? LockDoc
01-05-2012, 08:58 PM | #3 |
Re: wiper problem
yes
01-05-2012, 09:03 PM | #4 |
Re: wiper problem
If the motor stops immediately when switched off (doesn't return to park position), first check the motor's ground strap. Since the motor is mounted on rubber cushions, it's grounded via a copper strap attached under one of the mounting screws. This is the ground for the park switch so the parking feature won't operate if the ground strap is missing, dirty, or corroded. If the ground strap checks out okay but the motor still doesn't go into park then the problem is most likely a worn out or dirty park switch. The park switch is located inside the motor's gearbox so some disassembly is required to check/clean the switch. I recommend consulting a good repair manual for the motor disassembly procedure.
Check this thread I posted for more wiper Info.... http://67-72chevytrucks.com/vboard/s...d.php?t=413551 LockDoc
