01-05-2012, 09:28 PM | #1 |
Considering a C Notch in my truck - need opinions and input please
I am considering a Notch in my 69. The back is low now but still needs to come down some.
What brand would you recommend? I am thinking Porterbuilt but are there pros and cons by brand? The PB just looks stronger to me. I don't know, never done it before. What's the best way to cut the notch out? Will a Ziz wheel cut it? Do I need a Plasma cutter or ?? How do you guys cut it? I'm thinking I will just get the PB Stage 2 kit. I am discussing an ECE notch on another post .. are they ok? I can't find them on the ECE site. Thanks.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
01-05-2012, 09:34 PM | #2 | |
Re: Considering a C Notch in my truck - need opinions and input please
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
01-05-2012, 09:42 PM | #3 |
here are some pictures...
01-05-2012, 09:46 PM | #4 |
Dang Al .. What page is it on?
01-05-2012, 09:47 PM | #5 |
Oh, thanks man.
01-06-2012, 06:23 PM | #6 |
PB's bolt-in notch is 'multi-piece' which helps replace some of the frame strength lost when cutting the notched section out.
CPP also make a thicker, bolt-in, HD unit that's a good choice as well.
01-06-2012, 08:19 PM | #7 |
I recently fabbed up my own c-notch from 1/8th" flat stock. I simply took the measurements for my center line. made 2 60* bends and traced it out for a cut template. I could have made it a bolt on, but I was doing it while I was boxing in the frame, seems stiffer than it ever was. Wish I had a pic to post up.
It seems to me that your final purcahse decision should also depend on how far your total drop is going to be. I know you haven't mentioned "slamming" it. But how low is low? P.S. your cutting tool is going to depend on your level of patience. I have cut my long bed down with a sawz all, just not fun. I finally coined up and bought a plasma cutter, but for that little bit of cutting I wouldn't reccomend buying one. I really think a good angle grinder and cut off wheel might be your best option for that cut, which ever tool you use, make sure the frame is setting nice and level on jack stands. I knocked mine off the jack stands after cutting, it will bend :-( |
01-06-2012, 08:23 PM | #8 |
C/10 junkie
I've used the CPP notch and it is great, plus for less than $100 shipped to your door of eBay, you can't beat that price.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
01-07-2012, 12:12 AM | #9 |
Moderator
x 2. I am very happy with mine. I have some pics in my build thread.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
01-07-2012, 01:28 AM | #10 |
X3 I am running a CPP notch in my blazer. I used a zip disc to cut out the notch. It didn't take too long at all. All in all I think it took me about 4 hrs to do the whole job.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
01-07-2012, 01:44 PM | #11 |
I went with the PB stage 2 http://www.porterbuiltfabrication.co...-Basic-Kit-799
PB also has a mild notch seen here for $199 http://67-72chevytrucks.com/vboard/s...d.php?t=366945 Here is PB's 2 piece notch http://www.porterbuiltfabrication.co...in-C-Notch-225 I used a grinder with a cutoff wheel to cut my notch Nate
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
01-08-2012, 01:48 AM | #12 |
I used he CCP notch also. Check my build thread..
My build thread: 1966 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=486223 1965 GMC fleet http://67-72chevytrucks.com/vboard/s...d.php?t=651726 |
01-10-2012, 12:38 AM | #13 |
Here is mt sons C-Notch
01-26-2012, 09:30 AM | #14 |
Wow .. GRS, that one will be laying frame huh ?
01-26-2012, 10:58 AM | #15 |
I put the PB stage 2 in my 67 last weekend it worked great, I used a sawzaw to cut the frame. Hate those rivets!!
1967 swb 454 cid 700R4 trans SOLD 2006 Chevy Trailblazer SS 2013 Camaro RS convertible the wife's Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248 |
01-26-2012, 11:44 AM | #16 |
Happy to be here
My first choice would be to support or Forum Vendors. If I felt the need to order from a non supporting Vendor, I would look in our Feedback Forum and base my choice on Vendors with the best feedback.
01-26-2012, 11:47 AM | #17 |
I went with PB I'm thinking maybe sell a kidney or something so I can get the rest of it too. Ahh, .. maybe someday !
01-26-2012, 11:53 AM | #18 |
Happy to be here
Good choice. Nate will get you where you need to be.
01-26-2012, 12:39 PM | #19 |
C/10 junkie
How much is the PB notch??
01-26-2012, 12:47 PM | #20 |
$199 I believe, not sure. I got the notch and the upper shock bar, and it was $369 shipped. .. somewhere in that range.
I'm planning to get the frame braces, drop trailing arms, and lower shock relocation too (as soon as I can) Nate is talking about bags, maybe Shrader bags .. we'll see what happens. I probably will not be too terribly difficult to talk into it.
01-26-2012, 02:15 PM | #21 |
Here is the C-Notch I put in my 87. This c-notch also goes over the top of the frame. I had a quarter inch plate made to give it more strength.
01-26-2012, 03:03 PM | #22 |
C/10 junkie
I really like the Pb notch, but the cost is double the Cpp notch. But cause Nate's customer service and the fact that he is a forum vendor will ensure that I buy the notch for my 68 from him.
01-26-2012, 03:24 PM | #23 |
VA72C10
do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it do it!!!
Looking for a 67-72 swb or blazer project in or around VA. |
01-26-2012, 03:27 PM | #24 |
VA72C10
I think bags would be great....and bags with schrader valves aren't much more than drop springs...but give you some adjustment if you ever wanted to load anything in the back (can add some air) AND it lets you dial in ride height exactly.....
01-26-2012, 05:59 PM | #25 |
You took all my money punk !! Lol .. kidding.
I have to save up for the drop arms, will probably put (pretty much) the rest of the stage two kit on it when I can afford it.
