Old 01-06-2012, 10:31 AM   #1
ramrod7373
Crossmemeber swap
I have a 69 GMC and I found 81 Chevy for cheap. I heard on here that you can swap the front crossmember of the 81 to my 69, just neep to widen one of the holes. This truck has a fresh 350. I am wanting the 350 and the disk brakes off it. Is it possible to just swap the disk brake set up w/out too much trouble. Are the spindles the same as the ones from 71-72?
ramrod7373 is offline   Reply With Quote
Old 01-06-2012, 10:45 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Crossmemeber swap
read thru this....very good info regarding this swap....http://67-72chevytrucks.com/vboard/s...68&postcount=4...you'll need to focus on this "67-70 truck with 73-87 Crossmember Not Yet Installed:
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 01-06-2012, 10:57 AM   #3
ramrod7373
That is an excellent link...Thnx
Old 01-06-2012, 11:57 AM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
Your welcome, glad to help out....member lolife99 should get the major props for his hard work assembling all this great info.....
Geoff with a G
Old 01-08-2012, 11:51 AM   #5
chevyrestoguy
chevyrestoguy's Avatar
I just recently put a '79 suspension under my '64. On mine, I had to drill one new hole on each side and elongate a second hole on each side. Very simple.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
