01-06-2012, 12:16 PM | #1 |
sheet metal thickness ?? roof / doors ??
I am going to buy some sheet metal and am not sure of the gauge thickeness I will need ,anyone have any answers??
01-06-2012, 04:23 PM | #2 |
Re: sheet metal thickness ?? roof / doors ??
Most of the sheet metal on these years is 16-18 guage
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
01-06-2012, 08:05 PM | #3 |
the answer is .035 according to the piece 'I cut out of the roof..... I was asking because I was at work and was going to see the metal supply guy ..I bought 19 gauge . 20 gauge would be the closest at .0359.....
01-06-2012, 08:22 PM | #4 |
01-07-2012, 02:06 AM | #5 |
60-66 Nut
I typically use 18ga.
01-07-2012, 02:12 AM | #6 |
Same here.. Its a little thick for some things if you need to pound and shape it. Also when you weld it to the old metal, make sure you start on the new thicker metal so you dont burn a hole in the old piece..
My build thread: 1966 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=486223 1965 GMC fleet http://67-72chevytrucks.com/vboard/s...d.php?t=651726 |
