Old 01-06-2012, 07:19 PM   #1
J.Cagle
J.Cagle's Avatar
What motor should I have???
Just curious on what motor Ive got in my 63 c20. Its a v8 4 speed manual. Wondering because when I went to buy a starter I told them I needed one for a 283 4 speed, and one was not available. Got me to wondering If maybe I had something different. Thanks, Jared
1964 c-10 Long stepside, 230 I6 ,3spd, dealer add-on air.
J.Cagle is offline   Reply With Quote
Old 01-06-2012, 07:45 PM   #2
rbar
rbar's Avatar
Re: What motor should I have???
You should be able to get a starter for that one. My local O'Reilly gave me the wrong one for my 63 and their computer wouldn't pull up the correct one. A dozen years ago I never had that problem. I told them to give me one from a 70's and they could then find it. I took my old one to make sure the bolt pattern fit, because that's what was wrong with the first one. A 283 was available on your truck. If you get the numbers off of the block behind the driver's side cylinder head, I can tell you what it is. It should be seven numbers long. Here's some examples from 1963 trucks, but whatever V8 you have in that era should use the same starter. I think it's the same for inline 6 also, but somebody else can correct me if I am wrong. I am sure I used the same starter when I went from 6 to 8 back in 1987.
3789935 283
3849852 283
3864812 283
3889935 283
3782870 327
3789817 327
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 01-06-2012, 07:45 PM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
It would be the model that bolts to the bell housing instead of the block I believe. Does yours have the bolts mounting vertically into the block or horizontally into the bell housing?
Old 01-06-2012, 09:04 PM   #4
J.Cagle
J.Cagle's Avatar
It bolts horizontally. I bought a starter for a 283 with 3speed. Works just fine. Ill have to check out the numbers and see if its a 283 or not. Thanks guys!
