Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-06-2012, 11:56 PM   #1
myfirst72
help with my 72 4x4?
i have a lot of questions,most are probably just no briners for you folks here,but this is my first attempt at a restoration. i just got my 72 about 2 months ago and it seems like the right time to park it and work on it for a while. my first question,is there a kit to swap a 700 r4 in and keep my 205 t case? it has a th 350 now,and my gas mileage is killing me. will i have to cut or lengthen my drive lines if i were to put one in? its pretty much factory except the new ring and pinion and posi as far as i know. just a 12 bolt and 44. also looking for around a 4 inch lift kit,wheres a cheap place to look? NOT 4 wheel parts.
myfirst72 is offline   Reply With Quote
Old 01-07-2012, 06:44 PM   #2
Big-Blue
Big-Blue's Avatar
Re: help with my 72 4x4?
I am sure there are examples of that swap on this forum. I suggest you do a search.
As far as lift kits cheap, look for a used one on here or Rough Country has about the lowest prices for new springs up front and blocks for the rear.
Big-Blue is offline   Reply With Quote
Old 01-07-2012, 09:34 PM   #3
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
I would also suggest doing a search. I believe that the 700R is a little longer than a 350, but they both have the same bolt pattern. Which means you can use the same 205 adaptor for the 700R. As for lift kits, look on craigslist or search ebay. Personally I prefer procomp lifts. They are the softest ride I have ever had with a lift.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 01-08-2012, 09:53 AM   #4
Crash_OK
Crash_OK's Avatar
700R4 is 1.875 inches longer than the TH350. You would have to relocate the engine forward or the transfer case back (requiring modifications to your drive shafts).
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 01-08-2012, 08:33 PM   #5
myfirst72
i've looked around craigslist,but everything with in 2 hours of me is pretty much toyota dominated. im still planning as using it as my tow rig when race season comes around so im wanna avoid going with softer springs. would using 2 inch blocks in the front and rear still be safe for towing? also having the thought of going 8 lug since i have a 1 ton dually parts truck. is a dually rear end the same width as a regular? i would think id have to change the brakes over from the backing plate out. right?
Old 01-08-2012, 08:54 PM   #6
Chevy1TonFun
Grease Monkey
Block are fine for the back, but extremely unsafe for the front. Dually axles are wider than srw axles. I actually enjoy running a drw axle in the rear.
Old 01-08-2012, 09:14 PM   #7
myfirst72
well the dually is a 2wd so id have to find a 60 for the front. but if i were to use the dually rear,would swapping to the srw brakes and what not make it the same width? or are the axle tubes longer?
Old 01-08-2012, 11:12 PM   #8
Chevy1TonFun
Grease Monkey
its the axle tubes that are longer, not the hubs and brakes.
Old 01-10-2012, 01:28 AM   #9
myfirst72
how much wider is it? if its not goofy wide i wouldnt mind running it,but would i need a front axle to swap from a dually to keep the front wider or are the fronts the same width on dana 60's? i plan on eventually swapping to a f.i. big block and 4l80e so im pretty dead set on ditching the half ton axles to start with
